Question about The Computers & Internet
I have a Motorguide wireless series 55# thrust that is not working. When I push to test battery condition the 4 led's on the control module are flashing. Battery at full charge. What is the problem?
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 177 Answers
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Posted on Feb 18, 2010
rh10
  • 122 Answers
SOURCE: Thrust in FSX won't reach higher than 55% even with lever at full
This is either a calibration error, or a faulty stick. Nothing else can cause this. make sure you have the latest drivers installed or one's that it came with. Some operating systems will see the stick and load generic drivers which sort of work, but not fully. Always use the manufacturers drivers and install it using the correct route as in the installation as there are ways to install drivers that do not register them properly and you think they are installed but are not. Good luck with it.
Posted on Jul 13, 2010
shastalaker7
  • 1515 Answers
SOURCE: 1993 Dodge D350 diesel alternator not charging
Hi, I will keep this short, but just a tip on the tester they use, I had one bench tested and it showed up it was good and the built in regulator was good also. Put it in the auto along with a $75 battery, and the discharge light was still on!!. So, I checked all of the charging circuit wiring finding nothing wrong, and put a rebuilt alternator on. Took care of my problem, the alternator was intermittent, sometimes charging when they checked it at Auto-Zone, but stopped putting out when I put it back on the car. I lived 16 miles from the auto store, so it was a pain going back and forth, plus the cost of gas!! I would change it out if you can at this time. I am sure this is what is going on if all looks good under the hood as far as wiring. Check to see if you have the 75 amp alternator fuse under hood also. It may be gone. Make sure the hot cable to the alternator and wiring plug is OK. Change it out and you will be good!
Sincerely,
Shastalaker7
Please keep me posted on the out come and don't forget to rate me :))
Posted on Nov 20, 2010
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
Steering cable broke motorguide tr109 45
any marina/boat dealer and yes u can..rather simple too.
Aug 06, 2012 | MotorGuide Tour Series Freshwater Bow...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
