When i press menu and want to access the sound or anything else there's no writing to help me
I have a Robinair 347002K abnd cannot access anything under defaults. Defaults show as a menu item, but I can not see or select anything else under that heading I tried the 5454 password i saw on another...
You may did not try in the right way! The access code (5454) is 100% right for 347002K/347112K and 34700Z new series machines. If keypad has oil injection button (old series machine) press 8787 on keypad.
However you can try as following: To access the change Defaults menu press 5454 (If keypad has oil injection button old series machine press 8787) on the keypad then press ENTER/START arrow key. Now display will change to "Calibrate Scale". Press up or down key to select option you wish to access from: Set Tank Tare, Output Test, Input Test, Keypad Test. Prepare to Ship. Reset Board Memory etc...
NOTE: DO NOT CHANGE 'SET TANK TARE' OR PRESS 'PREAPARE TO SHIP' & RESET BOARD MEMORY' IF YOU ARE NOT FAMILIAR WITH THIS MACHIN!
Hope this will help you. Good luck!
Mar 31, 2011 | Robinair Cool Tech 34700Z Recovery,...
How do i set my internet,wap,mms,gprs and phone settings manually on my GB230
Hi, we will go step by step taking the example of Airtel Service provider..
Step 1: Provide an Acess Point
Go to 'Main Menu' then 'Settings' and then go to 'Access Point'
If you have activated Mobile Office then:
fill the follwing details.
Connection Title: Mobile Office (or anything you want to write)
Bearer: GPRS
Authentication: (Leave it as it is)
APN: airtelgprs.com
If you have activated Airtel Live then:
Connection Title: Airtel Live (or anything you want to write)
Bearer: GPRS
APN: airtelfun.com
If you have activated Airtel MMS then:
Connection Title: Airtel MMS (or anything you want to write)
Bearer: GPRS
APN: airtelmms.com
Step 2: Create an Internet Profile:
Go to 'Main Menu' then 'Settings' and then go to 'Internet Profile'
User Proxy: OFF
Access Point: select the one that you have created for mobile office in access point setting.
User Proxy: ON
Proxy Server Adress: 100.1.200.99
Proxy Server Port: 8080
Access Point: select the one that you have created for Airtel Live in access point setting.
User Proxy: ON
Proxy Server Adress: 100.1.201.172
Proxy Server Port: 9201
Access Point: select the one that you have created for Airtel mms in access point setting.
Step 3: Activating a Profile:
Go to 'Main Menu' then 'Web' then 'Settings' and then go to 'Profile'
then select the profile that you want to activate.. if then it dosent work then you can try restarting the handset...
NOTE: For working on Mobile Office, first you need to get it activated from airtel.. just call the customer care, talk to the representative, and ask them to activate the MO service after checking the tarrif.. and the enjoy surfing and mms_ing
Oct 25, 2010 | LG GB230 Cell Phone
MFC-240C PRINTER DISPLAYS "INIT UNABLE 4F" WHEN TURN ON
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Laserjet 3600 HP printer in wrong language in display led screen
When you say writing, I assume you mean the language on the printer's display. Here's a step by step guide (since I assume you can't read the Japanese).
Press the blue Checkmark button to access the menu system. Press the down area twice which will give you access to the configuration menu. Press the Checkmark button to select this menu. Press the down arrow twice to access the system setup menu. Press the Checkmark button to select this menu. Press the down arrow 13 times (you can just keep pressing it until it gets to the bottom. It won't go any farther than the last entry) to get to the very last entry which is language.Press the Checkmark button to select this menu. The languages will be displayed in their native scripts. The first one is English. Press the Checkmark button to select English. And you are done. Press the U shaped arrow to get back to the main menu.
Sep 20, 2008 | HP LaserJet 3600dn Printer
Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
May 28, 2008 | Zenith C27A24T 27" TV
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Zenith tv wont unlock
It should be a good enough reason for an exchange if possible. And should be covered under warranty, if not. However, if you want to try and fix it yourself......
Yes there should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
toggled from 1 to 0
5.Feature 16 unlock the auto-program (change to 0)
Feb 17, 2008 | Zenith C27A24T 27" TV
Ctc 195 sereis tv
Try unplugging your set, If you didnt save the changes this should reset it back to default settings. If that desnt work, you will need to go bak into the service manual and adjust the horizontal size. Just write down anything you change so you can revert back if you have too.
Jan 22, 2008 | RCA P56950 56" Rear Projection Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
