Question about HP LaserJet 4600dn Color Printer
Computer cannot find HP 4600dtn printer
We have had an HP LaserJet 4600dtn for years. We just moved it from one business to another (from the main office with a server that someone else completely set up and installed the printer to a plain old office with 2 computers). I have plugged the printer into the router (Cat5 cable) and the computer cannot find it. I have restored factory settings on the printer and still cannot find it. Computer O/S is Vista and I'm not sure if that's part of the problem or what or if I need to set something else up through the router, permissions, IP address or something. I'm totally lost and cannot seem to find anyone else anywhere on the internet with the same problem or an answer to this problem. Please help!!
  • jennica664 Jul 24, 2009
    I'm currently in Bandera, TX at our dude ranch...but am typically in AZ.
    I did manually set the IP address and was still unable to find the printer. I'm just starting to wonder if maybe something is wrong with the plug in the router....I'm going to check that next.
  • jennica664 Jul 26, 2009
    It actually was the router. I switched the port it was plugged into and everything was fine. Go figure!
    Thanks for your help!
    Master:
  • 409 Answers
You will need to find or set an ip address for the printer. if you are lucky the printer will be set to dhcp and will have an address, if not you will need to manually set an address. After that you will need to configure the pc's with "LPR" ports that will talk directly to the printer.
Where are you located?
Posted on Jul 24, 2009
  • Cosma Papouis
    Cosma Papouis Jul 24, 2009
    The Router is probably fine. If you like I could remote control your pc and set it up
  • 724 Answers
The plain old office with plain old XP on the computers? I hope you held on to one computer with XP. Vista is still in it's ruff stage...
I remember that there is a SEARCH in the START button ! Look for Computer or People , a COMPUTER ON THE NETWORK, A popup will have a text box in it leave it blank, Press search. Anything connected to your router should appear in the popup to the right it is part of your INTRANET defined as your internal network.
Sometimes you need to set the nework items DHCP so it will automatically set the IP addresses and the submask...
EG IP... 192.169.1.1
Submask 255.255.255.0 this one has to be the same on all the devices if mot then they will be in a different relm and can not be seen or it can not see the other devices.
Why is there permanent storage init error?
web search HP laserjet printer error codes
Sep 15, 2015 | HP LaserJet M1005 Printer
Code d'erreur 53.11.03
code error 53.11:03
ram dimm memmory error slot 1 unrecognized memmory configuration (unsuported memory) remove and replace
Jan 29, 2014 | HP LaserJet 4600dtn Printer
I have a hp color laserjet 2820, it says "replace supplies" and "device busy" . It was working fine yesterday and now won't print.
The replace supplies means that something has either reached end of life or has failed and needs to be replaced. Device busy usually indicates that there is a print job queued in the printer that needs to print, but the supplies out is stopping that from happening. Clearing the print queue on your computer and then restarting your printer might clear the device busy error, but the supplies error will likely require replacement of something.
May 01, 2011 | HP LaserJet 2820 Printer
Noise from back center area, loud humming/fast vibrating noise when doing calibration on my hp 4600 printer
possible fuser issue..in the control panels.. you can go into diagnostics and actually run individual components.. give that a tray..
Dec 15, 2009 | HP Color LaserJet 4600dtn Printer
L'imprimante affiche en permanence le message d'erreur 51.2M Comment le résoudre. Merci
C'est un problème avec le laser magenta
vous pourriez essayer d'échanger un laser d'une des autres couleurs et de voir si c'est l'unité laser ou le contrôleur DC
Oct 22, 2009 | HP LaserJet 4600dtn Printer
How do I replace a fuser kit in such
Check www.precisionroller.com and look under your model of printer. It's expensive but well worth it. The instructions are packed with the kit.
Sep 24, 2009 | HP Color LaserJet 4600dtn Printer
Business cards get stuck in HP 4650
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
HP LaserJet 4600dn Color Printer Logo
242 people viewed this question
Seeker5211
Seeker5211
