Question about Breville Kitchen Appliances - Others
How do I return my broken toaster?
I have a toaster that is a year old this month. It no longer toasts the entire slice of bread in both slots. It is a four slice toaster I purchased from the Bay at $159.00. Extremely disappointed as I have been very pleased with the quality of Breville kettle I have had for over 10 years.
4 Suggested Answers
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 109 Answers
SOURCE: My 2 month old 2 slice toaster only toasts one
take it back to the store or send it back to the man. this is a factory defect
Posted on Aug 23, 2009
  • 9587 Answers
SOURCE: why won't outside elements on both slots of 4 slice toaster come on?
The heater wire has opened. You should be able to see where the break in the wire is. Unfortunately there is no easy fix for that. New toaster time.
Posted on Jan 13, 2015
Why won't outside elements on both slots of 4 slice toaster come on?
Jan 13, 2015 | Kitchen Appliances - Others
My 2 month old 2 slice toaster only toasts one side of the bread in one slot. Other slot is OK!
The heating element on one side is faulty. If it's only 2 months old, I'd return it -- this is likely not a simple fix.
Charlie
Aug 23, 2009 | Kitchen Appliances - Others
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Toaster burns everything
It sounds like the heating sensor is longer functioning and the toaster is probably kaput, unless you can find an independent repairman who works on small appliances. In my own experience even a pricey toaster last about 3-5 years. I had the same problem with the same brand, just a different style
Aug 15, 2008 | Cuisinart CPT-160 Metal Classic 2-Slice...
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Kitchen Appliances - Others Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
