My print has a shadow its about a mm to the right of each stroke
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HORIZONTAL LINES ON THE PRINT
Out of ink.
Posted on Jan 27, 2009
Cycle has been sitting about 6 months. when i start it gas pours out from under tank. I mean a lot of gas - it would drain the tank in a couple of minutes.
Has to be a faulty tap, they work by vacuum, or a crack in the fuel line. I would start by replacing the fuel line. check the link.
http://www.revzilla.com/parts/2002-honda-vt750ccd-shadow-ace#v2-facets%5B%5D=2684&page=1&page_size=96&sort=featured&tab=all&implicit_facets%5B%5D=228&implicit_facets%5B%5D=1889
If that model has a fuel pump, you should check the fittings an seals on it. Specs are oddly worded for 'Fuel Control'.
Displacement: 745.00 ccm (45.46 cubic inches) Engine type: V2, four-stroke Compression: 9.0:1 Bore x stroke: 79.0 x 76.0 mm (3.1 x 3.0 inches) Valves per cylinder: 3 Fuel control: Single Overhead Cams (SOHC) Cooling system: Liquid Gearbox: 5-speed Transmission type,
final drive:
Chain 2002 Honda VT750C CD Shadow ACE Parts Accessories
Apr 16, 2016 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
What are the torque settings for the head on a 1e engine
toyota e engine guide - Toyotagtturbo.com
www.toyotagtturbo.com > ... > Modification/ Technical Questions
Sep 15, 2009 - 7 posts - ‎7 authors The 1E is a 1.0L (999 cc) carbureted 12 valve SOHC engine. ... Specs: 74 mm Bore 77.4 mm Stroke 9.6:1 Compression Ratio ... Engine Code Head Design Valves/Cylinder Date CC Peak HP Peak Torque Bore Stroke CR 1E ...
[PDF]Full page fax print - AMC Eagles Den
www.amceaglesden.com/images/Downloads/ENGINE%20MANUAL.pdf
All information and specifications in this manual are based on the latest data available at the time of .... 1E ENGINES Cylinder Head Bolt Torque Specifications ...
Oct 07, 2015 | Cars & Trucks
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
I have a yzf 426 yamaha. What fuel do I put in it? What oil do I put in it? Is it a 4 stroke motor bike? Please help me - Thankyou!
Model: Yamaha YZ 426 F Year: 2002 Category: Cross / motocross Rating: 71.6 out of 100 Engine and transmission Displacement: 426.00 ccm (25.99 cubic inches) Engine type: Single cylinder, four-stroke Compression: 12.5:1 Bore x stroke: 95.0 x 60.1 mm (3.7 x 2.4 inches) Valves per cylinder: 5 Fuel control: DOHC Cooling system: Liquid Chassis, suspension, brakes and wheels Front suspensiontravel: 300 mm (11.8 inches) Rear suspension travel: 315 mm (12.4 inches) Front tyre dimensions: 80/100-21 Rear tyre dimensions: 110/90-19 Front brakes: Single disc Front brakes diameter: 250 mm (9.8 inches) Rear brakes: Single disc Rear brakes diameter: 240 mm (9.4 inches) Physical measures and capacities Dry weight: 105.0 kg (231.5 pounds) Seat height: 998 mm (39.3 inches) If adjustable, lowest setting. Overall height: 1,303 mm (51.3 inches) Overall length: 2,171 mm (85.5 inches) Overall width: 827 mm (32.6 inches) Ground clearance: 375 mm (14.8 inches) Wheelbase: 1,490 mm (58.7 inches)
May 02, 2011 | 2002 Yamaha YZ 426 F
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
Nov 08, 2010 | Office Equipment & Supplies
Shadow black spirit full specifications horse power top speed colours consumption full run down etc
General information Model: Honda VT 750 C2 Shadow Year: 2003 Category: Custom / cruiser Rating: 74.9 out of 100. Show full rating and compare with other bikes Safety: See our safety campaign with the high safety rated bikes in this category. redirect;adid=212507406;sz=1x1;ord=[timestamp]? Engine and transmission Displacement: 745.00 ccm (45.46 cubic inches) Engine type: V2 Stroke: 4 Power: 45.00 HP (32.8 kW)) @ 5500 RPM Torque: 63.00 Nm (6.4 kgf-m or 46.5 ft.lbs) @ 3000 RPM Bore x stroke: 79.0 x 76.0 mm (3.1 x 3.0 inches) Gearbox: 5-speed Transmission type
final drive:
Chain Physical measures Dry weight: 229.0 kg (504.9 pounds) Seat height: 700 mm (27.6 inches) If adjustable, lowest setting. Overall length: 2,455 mm (96.7 inches) Overall width: 980 mm (38.6 inches) Chassis and dimensions Front tyre dimensions: 120/90-17 Rear tyre dimensions: 170/80-15 Front brakes: Single disc Rear brakes: Expanding brake (drum brake) Speed and acceleration Power/weight ratio: 0.1965 HP/kg Other specifications Fuel capacity: 14.00 litres (3.70 gallons) Further information Parts and accessories Check out parts and accessories from our partners. newflag2.gif Ask questions Join the 03 Honda VT 750 C2 Shadow discussion group,
the new Honda forum at Bikez.name or
the new Custom / cruiser forum at Bikez.name. Insurance, loans, tests Check out insurance here. Search the web for dealers, loan costs, tests, customizing, etc. Related bikes List related bikes for comparison of specs
Oct 26, 2009 | 2003 Honda VT 750 C2 Shadow
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
What kind of oil does my honda shadow 750 aero take?
As this is a 4 stroke bike, it will take 4 stroke motorbike oil, you can buy this from any good garage
Apr 21, 2009 | 2004 Honda VT 750 Shadow Aero
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
23 people viewed this question
k24674
jasbo
jasbo
