Question about Belling Ovens
I have a belling oven Bi 70F , I have replaced the fan but a few wires have come away from the power terminal , Earth , orange and black , not sure where to put the . The block is numbered 1 2 3 4 5 .
  • 2336 Answers
SOURCE: Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If you have this user guide go to page # 40 for wiring instructions.
Posted on Apr 09, 2008
  • 1462 Answers
SOURCE: belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Posted on Sep 30, 2008
  • 417 Answers
SOURCE: How to wire SMEG Oven SA9066CER
Yes that sounds o.k
Posted on Nov 30, 2008
WRMtech
  • 70 Answers
SOURCE: i need to put new terminal block in oven so need to know where
keep all the L1 & L2 leads to the outside terminals and only the N wires go in the middle.
Posted on Feb 21, 2009
  • 157 Answers
SOURCE: belling oven fan works without heating the oven???
element
Posted on Jun 30, 2009
What is the current draw on an omega Europa 40-1 elec oven please
7
ELECTRICAL INSTALLATION
WARNING
This apparatus must be earthed.
The oven is only for domestic use.
The feed voltage and the absorbed power are as indicated on the data plate attached to the left-hand side
upright, which can be seen when the oven door is open.
Connecting must be carried out by qualified personnel and in accordance with the regulations currently in force.
The manufacturer cannot be held responsible for any
damages to persons or objects caused by failure to
observe these instructions.
If the supply cord is damaged, it must be replaced
by the manufacturer, its service agent or similarly
qualified persons in order to avoid a hazard.
The oven must be connected to the mains through a multipole circuit breaker with a contact-to-contact
gap of at least 3 mm, making sure that the earth wire is not disconnected.
For connecting use a flexible cable of the
H05V2V2-F 3x1,5 mm2
type remembering to make it long enough
to allow the oven to be removed from its housing un
it when maintenance work is required.
To connect the cable to the oven, proceed as follows (see Fig. 2):
- Remove the lid (1) by unfastening the three screws (2).
- Unfasten the two screws (3) for the cable holder
and feed the cable through the opening immediately below
the cover.
- Remove about 12 cm of the outside insulation from
the cable and shorten the two active wires (live and
neutral) to 6 cm, leaving long the one to be connected to the main earth terminal on the terminal box;
remove about 1 cm of the main insulation from the three wires and connect them correctly to the terminal box,
Remembering to respect the polarities.
- Tighten the two screws (3) of the cable holder and put the lid (1) back on with the three screws (2)
Electricals Specification
Absorbed power:
Oven top element:
2000+1000 W
Oven bottom element: 1200+400 W
Lamp:
25 W
Hot air fan motor:
25 W
Cooling fan motor:
25 W
Maximum absorbed power:
(see data plate).
Supply voltage:
(see data plate).
Aug 22, 2017 | Ovens
Element went in fan oven i replaced this but now there is no power going to it
Make sure you have wired it properly. There is usually 3 wires. Earth (Green wire) an active and a neutral. The green wire should be on a terminal which is connected (Welded) to the outside of the element body. If this is Ok, there may be an inline fuse somewhere on the oven which has blown. Usually situated near where the power cable comes into the oven. Check your meter box to make sure the circuit breaker hasn't tripped off.
Mar 08, 2015 | Ovens
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
I have removed the element from my technika fan forced wall oven. Not sure which wire is the earth ? There are 3 wires. onehas two wires running to the terminal clip and the other two are single...
Simple the colour of the wire will give you the direction of their function what you need to know are the color of the wire.
However, if there is red wire among the two wires or( white or yellow) the white means and the red means power.
Good luck and then make sure that all electric power are disconnected .
Thanks for using fixya.
Jul 30, 2011 | Ovens
Ive taken element out to replace with new but have forgotten the way the wires went back.there are three spade connections the earth is obvious but not the live and neutral
Hello Ian,
You can put the live and neutral on either of the outer terminals terminal. It really doesn't matter. It's the same principle as not needing to screw in a bayonet light bulb a certain way round. As long as the circuit is complete, it will work correctly.
To put it in the simplest terms, attach the earth wire to the shorter centre terminal with the live and neutral wires on the two outer terminals and job's a good 'un.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 18, 2011 | Belling XOU252 Electric Single Oven
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
ELEMENT KEEPS BLOWING
The heater element should have 2 terminals , it does not matter which wire you put on the terminals, as they are both common,
If there is a third terminal, then that will be the earth terminal, which is usally located on the base of the element fixing bracket. so do not get the wires mixed up, because if you are putting the earth wire on the wrong terminal, it will blow.
Hope this helps you sort it out.
Dec 16, 2009 | De Dietrich Ovens
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Ovens Logo
27 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
