Question about Tablets & eReaders
How can I place myself as admin.control.
Tablet won't allow me trough settings
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
I just purchased an RCA Viking pro tablet which I can't set up because it was previously synced with another google account.
A lot of the time you can connect to a computer and download the the program for the tablet, and erase it back to the factory settings. hope this helps
Nov 10, 2017 | Tablets & eReaders
10 rca tablet keeps losing connection have to shut down to get it to connect
Try setting it to a static IP address.
open router settings (type your routers ip address in web browser I.e.192.168.1.1)the admin name and password are normally on the router)then lan settings
set the MAC address of tablet as static noting the IP address (192.168.1.4 for example),subnet mask (normally something like 255,255,255,0),etc.( to find your tablets MAC address settings then about)
when you have set the router up, on tablet tap the settings then wifi, modifiy settings tick use static scroll down and enter new ip address ,subnet mask default gateway(your routers in address).
its easy then it looks.
Sep 13, 2017 | Tablets & eReaders
My p902 tablet won let me use google play store.. Why?
Have you signed your tablet into Google? Go into apps, click on Google settings, and sign your device into Google using your account. If you don't have an ac punt, great one. After that you can set your device/ tablet to always allow you to use any Google app without having to always sign in. It will be automatic.
Nov 29, 2015 | Tablets & eReaders
Why does my facbook crash everytime i open it
Hi Steve
There are many reasons why you could be prevented from accessing fb from your Tablet. One of which is the configurations. The settings on your Tablet could have been set to do that. If someone else did the configurations e.g. a parent configuring a child's laptop or Tablet, parental control settings allow parents to determine which applications can be accessed and which cannot.
Only for your information.
Oct 24, 2014 | Tablets & eReaders
Place where i charge my tablet is broken
Easiest way without voiding your warranty would be send it for RMA. If it's not possible and you feel daring, you can buy the new part, open up the tablet and replace the connector
Jul 02, 2014 | Toshiba Tablets & eReaders
Parental control password reset for a d2 tab
Hi Michelle, if you're willing to completely reset your tablet you can use the following procedure.
First turn off the tablet. You should then proceed to hold the power button and the up- volume button simultaneously. Carry on holding the buttons until you see a blue light. Continue to select factory reset, Delete All User Data and finally 'Reboot System Now'
Apr 10, 2014 | Digital2 7 inch Tablet with 4GB Memory
I bought a sophix tablet from gamestop for my kid and i wanted to disable the browser but when i go to apps - browser - it does not let me disable it (disable button not able to be pushed bc blank) I...
The browser component of the Android tablet is a built in software package. It cannot be easily removed, disabled, or otherwise hidden. However, there are other applications that you can download from the Play market that allow you to mask what applications your child can interact with. These applications, when downloaded, will allow your child only to have access to the parts of the tablet YOU say they can, and nothing else.
Some suggestions:
  • Kids Place - Parental Control
  • Famigo
  • App Lock
While the three above are just the top three in the market that do what you want, there are plenty of others to choose from as well.
When sharing a tablet, phone, or smart device, it is wise to setup an environment that is safe for the other person while still keeping control. These applications allow you to specificy what you want shared, allowed, and available on the tablet, without affecting the operation of the machine. So, they should work for you quite well.
Dec 23, 2013 | Tablets & eReaders
MEEP tablet is saying time's up! what can I do to fix?
If you are receiving a message on your Meep of 'Times Up!', please try the following steps:
1. Register your Meep. Many of the capabilities of the Meep require the parent account to exist which puts the Meep into our system.
2. Adjust your parental settings to allow for times of use. You must set a time limit for every type of allowed activity and then save those settings. If you did set up permissions and you have the Times Up message, check that your settings are the way you set them and haven't been changed. 3. Update your Meep to our latest firmware version using our Meep Ota App available in the Meep Store and through Google Play. Earlier operating versions are linked to the Times Up issue.
If you still have a Times Up message:
1. It could be an issue within your browser in that it's retaining old settings and not updating them. Try clearing the browser cache and/or disabling extensions within your browser. Another option is our Meep Together smartphone app which can also be used to adjust parental settings instead of the portal website.
2. It could be your Meep is not connecting at this time to our servers thus not being able to receive the updated settings. Check that you show a green dot which means you are connecting to us or send a Private Message with your serial # and we can check the connection from our side.
3. Another option that bypasses servers is that you can update the settings right from the Meep's own parental control interface, assuming you are on version 2.1. Additionally, within the parental app on the Meep, you can reset the timer for the Meep with the reset button, the small circular icon in the upper right hand corner of the time management screen. Once reset, you can adjust the settings as you wish.
Feb 26, 2013 | Oregon Scientific MEEP Android Kids Tablet
How do I enable presentation mode on an XT2 tablet? I am in a meeting connecting a Dell Tablet XT2 to a Panasonic projector via vga cable and trying to use Fn8 to display the laptop screen. The setting...
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
Nov 05, 2009 | Dell Latitude XT2 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
