Question about Shoprider Health & Beauty
I have current at the tiller head but no forward or reverse motion. Where do I look first. Many thanks.
Shoprider Altea boot scooter. On/off switch lights up, battery indicator shows full charge, horn works.
  • Shoprider Master
  • 1,057 Answers
Hi check the freewheel lever make sure its in drive lock position.cheers
Posted on Apr 23, 2017
  • Mr D G Webb
    Mr D G Webb Apr 23, 2017
    Thanks Jeff. Although it wouldn't move yesterday it was fine this morning so it's not that simple.
    Will lift it onto the bench when I get clearance from hospital & investigate a bit further, I hate intermittent faults.
  • Jeff Tilburn
    Jeff Tilburn May 14, 2017
    If it will not move forward or reverse check the resistance of potentiometer that is connected to the paddle lever .u will need a multimeter good luck
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Help me Help you ...
Sep 24, 2015 | Shoprider Health & Beauty
Has NO reverse but goes great in forward help
This sounds like the Wig-Wag could be at fault or the wiring to the controller.
Apr 06, 2015 | Shoprider Mobility Products, Inc. Hero...
My shoprider jolts and shakes on reverse it is only 3 months old
The result of data corruption that can occur when power is low enough to get interupted by the load of a motor. The above solution it the correct thing to try first/
Jul 11, 2012 | Shoprider SL73 Echo 3 Wheel Scooter ()
The forward/reverse lever on my shoprider cooper is loose. How can I repair it?
hi, you need to take the tiller apart and refit the spring ... this does happen, a picture will help and i can advise you what to do ...
Jun 09, 2012 | Shoprider Cooper Scooter in Red
My scooter will not work when you select reverse , i need to go forward and immediatly go into reverse to make it work ,,why ?
it sounds like the speed pot is faulty, or otherwise known as a wig wam,
it sounds like its worn or simply come loose, there should be a allen screw in the side of the throttle lever, when in central position , tighting up the allen screw .
Also check the connection between the pot and main board it plugs into.
Oct 06, 2009 | Shoprider Mobility Products, Inc. Hero...
Forward/reverse pot is flaky, where can I buy one?
You will need the make, model and the serial number off your scooter. The serial number should be on the frame down under the shroud cover under the seat. Call the manufacturer with this info, and they will either issue you a part, or usually, refer you to an authorized repair facility for replacement of the part. Replacement is pretty straightforward once you have the tiller shroud opened up. Good luck.
Jul 23, 2009 | Shoprider Scootie TE-787NA - Power Scooter...
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Jun 29, 2009 | Kitchen Appliances - Others
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
Health & Beauty Logo
70 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
