Question about Frigidaire Dishwashers
I noticed the inside of the dishwasher was very hot. it had not been run in 2 days.
    Problem Solver:
  • 10 Answers
There must be a cycle malfunction or a short or some sort in the controls.... you'd have to take most of your dishwasher appart to fix this, but make sure to turn off the breaker/fuse to this apliance befor taking anything appart.... it would probably be best if you'd turn the breaker/fuse off untill you have this problem resolved... this probleme/malfuction may be a fire hazard!
BE CAREFULL
Posted on Jul 24, 2009
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
Sand on inside of cups and glasses on top rack of dishwasher
it souds to me like lime scale detaching its self from the heater element.
try calgon, it should fix it
Jun 03, 2012 | GE 24 in. Profile PDW7880G Built-in...
My whirlpool motor does not sound like it kicks on when started. The dishes are not getting cleaned...and water remains in the bottom. When I hit drain, it will drain. I also recently noticed that I am...
Yes it's most likely related. Your dishwasher dumps all the debris it washes off the dishes into the garbage disposal. I'm not a dishwasher distributor so I can't tell by the model number just what dishwasher you have.
Most people dump little thing in the disposal through out the day with out thinking about it or running the disposal, try running the disposal while your running the water to warm it up.
If your dishwasher has a built in garbage disposal, then from what you've described I would say something either a small metal utensil or a piece of glass has gotten down into the dishwasher's disposal and damaged the blade.
If your dishwasher doesn't have a disposal then it's most likely gotten into the pump impellor and broken off some off the teeth.
Another thing I've run into is that the lines inside the dishwasher get holes worn into them, either from the hot water going through them or the spray, I don't know which is the cause. Pull the trays out turn the top one over and check the line for damage. While the trays are out check the other lines and the pump for visible signs of damage.
Jun 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
Apr 26, 2010 | GE WBVH6240F Front Load Washer
Dishwasher doesn't clean well
Just got done working on my wife's after she holler at me for the same problem...
Found that there was a ton of **** at the bottomjust inside the door. Also the float switch, which looks like and unsidedown cup at the bottom front of my dishwasher had goobs of olf food up underneath it. The spray arms were full of undisolved soap, paper, and plastic. Beats me how that got through the filter, but it did...
Also found that the bottom spray arm cap is broken...ordered parts for everything from repairclinic.com and with shipping it was less then fifty bucks...new spary arms, ends for the rack rails that were broken, the bottom spray arm cap...totally redoing the insides...
Then washed it out with a strong (couple of cups) of clorox. Then a cycle with just dishwashing detergent...my wife is happy!!! and will be happier once I install the new parts...
Also check out this tip...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
Heatman101
Mar 22, 2010 | Dishwashers
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Mar 24, 2008 | Dishwashers
Dishwashers Logo
63 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
