Question about Pentair Pool & Spa
The wheels of my dominator Pentair are slipping against the walls and does not turn anymore
    Top Expert:
  • Pentair Master
  • 8,471 Answers
Take cover off see if hoses came off or adjust wheels
Posted on Aug 30, 2017
My Gw9500 won't climb all walls in my pool
get one of your kids to do it by hand. Those things never do anything except destroy your pool and income.
Jun 10, 2014 | Pentair Kreepy Krauly Great White GW9500
Wheels turning slow on legend pool cleaner
Water supply issue...
Most likely reason = clogged finger screen at pool wall fitting adaptor, this needs to be cleaned regularly. If no finger screen, then the debris that would've been trapped, has clogged your internals of the cleaner!
all orifices will need to be cleaned.
Oct 28, 2013 | Pentair White/Gray Legend Platinum...
Pentair front wheels not turning
make sure the inside of the wheels arent stripped they are gears if loose take apart adjust out so they touch the other gear that should fix that if gears are stripped you can change the front wheels to the back
Oct 19, 2013 | Pentair White/Gray Legend Platinum...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair legend front wheel does not turn
remove cover and adjust wheels to gear or if stripped switch front to back
Jul 07, 2012 | Pentair White/Gray Legend Platinum...
Pentair pool cleaner won't stay locked in
bad in-wall fitting see if tabs ore off if broken replace if cannot get out of wall turn off pump put fitting in wall and then try with channel locks to remove
Apr 02, 2012 | Pentair White/Gray Legend Platinum...
I have a 2006 yz250f and it seems like the clutch is slipping in 5th but its great in all the other gears
If it is going to slip, 5th is where you will notice it first, so it may need new plates, the alloy ones can wear as well as the fibre ones.
Make sure you are using four stroke motorcycle engine oil ( car oils can cause clutch slip due to friction modifiers)
A rough check of the clutch can be done by placing the front wheel against a solid wall, selecting 5, and a handfull of revs, drop the clutch, the engine should stop immediately, if it spins over even a couple of times with the clutch out, it is slipping and needs work.
Oct 15, 2010 | 2004 Yamaha YZ 250 F
Our Pentair Legend moves to a wall and stay there
Yes place the left jet (it rotataes) to the 11:00 position and the right jet to the 5:00 position and it will run correctly.
The Pool Tech
Jun 28, 2010 | Pentair White/Gray Legend Platinum...
My wife's mother had an old New Home Sewing machine. Instead of a belt drive off the motor this machine has a slip on rubber wheel about an inch in diameter that is spring loaded and presses against the...
I have these in stock. you'll need to give me the diameter of the rubber wheel as there are three different sizes. These run $5 +s/h. Stepping Stones Quilts
912-638-7128
Jun 11, 2009 | New Home L-373 Mechanical Sewing Machine
Pool & Spa Logo
111 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
