Question about Indesit Washing Machines
Wiring layout for indesit idv75 for front panel and door lock
kjmac
  • 97 Answers
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Posted on Nov 07, 2007
  • 119 Answers
SOURCE: front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Posted on Jan 31, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 85 Answers
SOURCE: FRONT control PANEL Wiring
You need to determine manufactuer of board go to there website and download the user manual ...
Posted on Jan 09, 2009
  • 1986 Answers
SOURCE: how do i remove the right front door panel
This is a universal description, your car may vary slightly...
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge and disconnect the wires.
Posted on Sep 09, 2009
My indesit IDV75 dryer is starting to smell like rotting meat
remove back and see if a rat or mouse has crawld in n died .......
cheers
May 24, 2014 | Indesit Dryers
When I programme my washing machine the lock light does not come on when the door is closed, therfore it will not start.
Possible that the DOOR lock SWITCH is faulty and so the continuity to the switch and the wiring to the panel must be checked.
If there is no continuity then the switch must be replaced.
Jan 15, 2013 | Indesit W 123 Front Load Washer
IT IS NOT INDESIT 123. IT IS INDESIT 133
its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
Nov 06, 2011 | Indesit W 123 Front Load Washer
HI MY INDESIT 1063W WILL NOT SPIN PUMP KEEPS ON GOING DOOR LOCK NEW NO FILTER ON FRONT OF MACHINE
There should be a removable plastic panel at the bottom front of the m/c.
I f there is and you remove it, you should see the filter there.
Dec 03, 2008 | Indesit Washing Machines
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
no easy way to open
Jul 10, 2008 | Indesit W 123 Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
W washer
it maybe door electric lock easy to fit,take door seal at the front ONLY,take off the two screws holding on lock,have new one in hand, lock I mean,copy the way the three wires are on the old one,swop for the new one.bye Ire.
Oct 23, 2007 | Indesit W 123 Front Load Washer
MICRO SWITCH
if you mean the door lock micro switch the is only two connections you can not go wrong Regards Engineer
Jul 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Washing Machines Logo
47 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
