Question about LG Washing Machines
My LG DirectDrive 7kg has done a load of washing and now we can not get the door to open !
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 85 Answers
SOURCE: my front load Tromm LG
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Posted on Dec 21, 2008
SOURCE: cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Posted on Jun 30, 2010
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
Cant open door
Apr 25, 2009 | LG Washing Machines
LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | LG WM1814CW Front Load Washer
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Sep 02, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
