How to start printer? - Office Equipment & Supplies
How to canon lbp 2900 self test page without pc
Make sure the printer turns on/on
  • Press the resume should not be removed
  • Keep press the button until the power lamp lights up resume/flashes twice
  • Then release the resume button
  • Jul 06, 2012 | Canon LASER SHOT LBP-2900 Printer
    N1 vision
    On your PC or Laptop that is on the wireless network
    Go to Start > Printer and Faxes > add a printer
    click network printer
    and then you should be able to figure out what to do, let me know how this works out for you. Good luck and if you need further help, let me know.
    Have a good day
    Mar 27, 2008 | Belkin N1 Vision Router
    How do I run an ink check?
  • Click "Start." From the start menu choose programs.
  • Click "Programs." Then choose "BJ Printer," then "BJ Printer Monitor." The Canon BJ Printer Monitor window will appear.
  • Click on the Canon icon. This will take you to the printer info menu.
  • Click "Start Status Monitor" from the Printer Info Menu. The Canon Start Status window will appear.
  • Click the "Ink Information" Tab to view the levels of ink in each tank in the printer
  • Jun 12, 2011 | Canon PIXMA MP830 All-In-One InkJet...
    I250canon printer ink levewls How do i check inklevels
    Try this steps, 1. Click "Start."From the start menu choose programs. 2. Click"Programs." Then choose "BJ Printer," then "BJ PrinterMonitor." The Canon BJ Printer Monitor window will appear. 3. Click on the Canonicon. This will take you to the printer info menu. 4. Click "Start StatusMonitor" from the Printer Info Menu. The Canon Start Status window willappear. 5. Click the "InkInformation" Tab to view the levels of ink in each tank in the printer.
    Nov 20, 2010 | Canon Office Equipment & Supplies
    How to reset the hp deskjet 920c
    1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
    2. Right-click the printer you want to use, and then click Set as Default Printer. A check mark is displayed on the printer icon to mark it as your default printer.
    gl_ico.png Tip
    To add a shortcut to Printers on your Start menu, right-click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click Properties, and then, on the Start Menu tab, click Customize. Select the Printers check box, and then click OK.
    Nov 10, 2010 | HP DeskJet 920c InkJet Printer
    The dell 3000cn printer on my desk keeps saying LOAD MPF A4 PLAIN 1. I have added paper into the tray, and checked that the settings from my laptop match up with the paper settings on the...
    gl_ico.png Tip
    Nov 10, 2010 | Dell 3000cn Laser Printer
    I want to print in just back and white, but my printer wont do it.
    In order to print in Black and White using grayscale, you will need to adjust the printing preferences within the driver. To change the printer properties complete the following steps:
    1. Open the Printers Folder:
    • Windows 2000: Click Start => Settings => Printers.
    • Windows XP: Click Start => Printers and Faxes.
    • Windows Vista: Click the Start button => Control Panel => Hardware and Sound => Printers.
    • Windows 7: Click the Start button => Devices and Printers.
    2. Right click on the Brother printer driver and left click Printing Preferences.
    3. Click the Advanced tab.
    4. Select Grayscale.
    5. Click APPLY => OK. Your printer will now print in grayscale.
    Oct 26, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
    Lexmark x2500 will not feed paper without help
    First, you can unplug the printer and replug. You can also restart the printer and computer. If printer is not detected then you should replace the printer cable.
    Second, Start > Run > type services.msc > OK
    Find printer spooler services > right click stop and then right click start.
    Find any lexmark services in the list. If you find any services the Right click and stop and then start in automatic.
    Third, Delete all temporary files, and folders.
    Fourth, Start > printer > open the printer and delete or cancel all the queue documents.
    Fifth, Restart the computer and printer . Now check.
    If problem still same then you need to uninstall printer.
    You should also delete all entry from registry key.
    After uninstall of printer, you can install a fresh installation of printer.
    Nov 19, 2009 | Lexmark Z645 InkJet Photo Printer
    Black page comes every time of printer started.
    Set the printer driver to "Do Nothing" on Startup , Head Close etc. the next print sent via the driver will fix the printer.
    Apr 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
    26 people viewed this question
    k24674
