Question about Samsung Televison & Video
Does the samsung model code ln46b75ou1fxza have any recalls on power supply board
Cool_dud 09
  • 206 Answers
SOURCE: power supply board
Hai,
Please check on here....you will find it out!
Posted on Aug 23, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
SOURCE: Samsung power supply & IP board BN44-00264B &
For anyone else with this problem...I ended up getting a replacement transformer from ebay and swapping it out myself.
You have to remove the back panel of the TV, unplug the board from the harness going to it, unscrew the board (both via the set of screws going directly through the board and the set going through the plastic piece on the opposite side that, as far as I could tell, the board is glued to). This plastic piece (running the length of the board) has receptacles for the backlight bulbs, so be gentle getting it in and out. Don't forget the screw in the middle of the board.
De-soldering was a little tricky. My soldering skills are not great, so maybe it was me. But it certainly seemed to be a little challenging to get it all out. Having so many terminals probably didn't help (a capacitor would have been easier). Eventually though, I did get it out. Soldering in a new one was easy. Be sure to check continuity between the terminals of the new part and other parts of the board using the traces as a guide once you're done.
After that, simply re-install the board and put all hardware back in. Like I said before, be sure you re-engage the receptacles of all the backlight bulbs by pushing down at each notch on that plastic part of the board.
Hope this helps someone else...
Posted on Dec 19, 2011
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
Posted on Mar 30, 2012
gopakumarg43
  • 75178 Answers
SOURCE: I PURCHAGE SAMSUNG MODEL NO. LA22A450C1 POWER SUPPLY BOARD
What is the problem you faces now? Provide more details; please. What was the problem that led you to replace the power board? I mean, the problem you did faced before replacing the power board. Give me as much as details as you can. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 02, 2014
I got samsung washing machine top loader the start button it quite no sound by pressing and doesn't start the machine.
I had the same problem faulty lid switch..... So meaning when the lid is shut the washer thinks it's open.....I ended up throwing mine out too expensive to fix....
my Samsung washing machine was a recall but found out too late check their recall models you might get it fixed on warranty...
cheers hope this helps
Apr 21, 2017 | Samsung Washing Machines
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
Model uahof55ooam has sound no picture model code UA40F500 SAMSUNG TV
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 09, 2016 | Samsung Televison & Video
Samsung 32" LCD TV
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 01, 2016 | Samsung Televison & Video
My samsung 1080p keeps clickingand will not turn on
its either in the power supply circuit or a signal board damaged
you might try calling samsung cusnsumer assistance and see if this one is under a recall for service
Jun 05, 2011 | Samsung 50" Slim-Depth DLP HDTV
I have a Samsung LN52A650A LCD TV that 3 years old. Today when I go to turn it on it just clicks and does not turn on. The clicking wont stop...it clicks about once per second. I have to unplug the TV to...
The tv power supply board have dead components parts call capacitors most likely.U have all the tools and understanding basic electronic also can do basic soldering too?The tv power supply board that the board where the power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and dead capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.Must replaced all these dying capacitors parts are bulging up ur puffing up on to it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
May 11, 2011 | Samsung LN52A650A LCD TV
Hi - My Samsung LNT5271FX 52" LCD TV won't turn on. It just clicks over and over and over, but never turns on. What's up? A relay?
This is a capacitor problem. Several Samsung models have bad capacitors installed on the power supply boards. Samsung currently offers a recall fix for this and other models. Call Samsung direct to see if your TV qualifies for this one time fix. It is a free fix, so if the person on the other end doesn't have a clue, ask to speak to a supervisor or hang up and try again.
Nov 02, 2010 | Televison & Video
I have a Samsung HDTV. Model Code HLR4667WAX/XAA,
IT'S YOUR DMD MODULE IT'S PART OF LIGHT ENGINE IN THIS PATICULAR MODEL WHEN THAT GOES BAD YOU HAVE TO REPLACE WHOLE LIGHT ENGINE CONTACT DISCOUNT MERCHANT OR RIVER VALLEY ELECTRONICS THEY HAVE THEN FOR PRETTY CHEAP.
Jun 24, 2009 | Samsung Televison & Video
Samsung spn4235 need power supply
You can order the original Samsung replacement Power Supply Board for this model (SPN4235) from a major Samsung parts distributor at the link below:
Samsung SPN4235 Replacement Part SMPS Switch Mode Power Supply Board
Apr 08, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
