Question about Toshiba Televison & Video
Toshiba rdxv60kb turns on then shuts down 30 seconds later - no tape in !
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
  • 883 Answers
SOURCE: Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Posted on Aug 30, 2007
  • 3 Answers
SOURCE: i have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Posted on Aug 10, 2009
  • 12 Answers
SOURCE: set keeps shutting down
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Posted on Jan 28, 2010
ladywinn
  • 5138 Answers
SOURCE: I have a wd65733....When I turn the set on, I get
CK Lamp and Lamp Fan, Mats has Lamps for $99.00
other companys want 273.00 1-800-628-1118
Encompass Parts Distribution has Free service Manual for this Model, you can print out online.
Posted on May 10, 2010
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
Jun 12, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
Why does my recorder turns it self off?
Look for a Reset and hold it in/on for 5 - 10 seconds. Apart from that I have no idea sorry, Greg.
Jun 29, 2014 | Toshiba RDXV60KB DVD HDD VHS Recorder
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Toshiba vhs dvd combo will not play tapes run for about a count of 3 on face then shuts down completly
I had the very same problem and it was an easy fix. Remove the top cover and you will see a clear plastic post with an extension over a black plastic gear with two cutouts. This senses tape movement. Remove the clear plastic post which is held on by one screw. On the printed circuit board below where the clear post was you will see an infra red led. clean the led and the clear plastic and reassemble. That should fix the problem. Good luck
Apr 02, 2012 | Toshiba DVR620 DVD Recorder/VCR
My computer has frozen on preparing for stand by and I am unable to turn it off
Hold down the power for about 30 seconds or more and the computer should shut down, if not remove the battery from the back of the laptop and then replace after 30 seconds and reboot the mechine.
Aug 21, 2010 | Toshiba Computers & Internet
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
I have a acer AL2216w. it randomly shuts itself off
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
Aug 30, 2007 | Toshiba M655 VHS VCR
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
