Question about Indesit Washing Machines
Indesit idc85 does not heat up. Everything else is fine. Can't find a reset button. Help please
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: indesit idc85 will not work or heat up
follow this steps and fix it. God bless you
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gWEW0sFp
Posted on Oct 02, 2013
SOURCE: My indesit idc85 spins just doesn't heat up
This is a serious problem , there can be repaired at home , it should be taken to a specialist. There are little chances for heating system to operate.
Posted on Nov 11, 2016
Nov 11, 2016 | Indesit Washing Machines
Not happy that my product is one effect
contact the manufacturer and ask for a refund on the machine
show proof of the document that it is a fire risk ( recall or alert document)
Nov 24, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Indesit idc85 not collecting water in container.
well it could be one of two things its blocked up which means you need to clean all tubes out or the pump is faultyif you take the top of dryer and pore water into drum and turn you should be able to see if water comes up tube if not check your pump
Oct 14, 2014 | Dryers
My dryer has a queaking drum
if squeek at back.......could be bearing.............
.at front ....could be plastc slippers
cheers
Jun 19, 2014 | Indesit Dryers
How to replace fan belt indersit IDC85
use the manual to change the fanbelt: http://www.indesit.co.uk/indesit/_pdf/manuals/19508388602_GB.pdf
Jun 15, 2014 | Washing Machines
Indesit IDC85
belt fits againt the spring............
cheers
Apr 11, 2014 | Indesit Dryers
Indest IDC85
you will have to check it will be on or near element you will have to take back off and if there is no reset button check your element could be a stat on element that gone
Jan 23, 2014 | Dryers
Indesit idc85 will not work or heat up
2. Heating element
3. Thermal fuse
Oct 01, 2013 | Indesit Dryers
Washing Machines Logo
41 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
