Question about The Office Equipment & Supplies
Root of the word unavailable - The Office Equipment & Supplies
Mac-address wifi unavailable and bluetooth address unavailable.
- go to data/misc/wifi (required root)
-backup file wpa_supplicant.conf in this folder which contains usename and password wifi
- delete all file in this folder
- turn on wifi ( if you careful, you can reboot )
- now you can connect to wifi
- recovery file wpa_supplicant.conf
Sep 12, 2016 | Huawei P8 Cell Phone
LG G2 D801 3G not working after update Android Lollipop
LG support number is 800 243 0000 they are very helpful. thank you
Jul 12, 2016 | LG Cell Phones
Unlock us cellular network
you aren't going to get a legitimate answer to that question on this forum. try www dot xda-developers dot com.
Feb 11, 2014 | Cell Phones
IP Address unavailable/ cannot hook up to internet
Has it been rooted?
The equivelent of a an ipad/iphone jailbreak?
You can check this by doing one of two things.
The first is by going into settings, scrolling down to the bottom and clicking on About Tablet.
If not that then go to Settings/Device and then click About Tablet.
The second, and easiest, is to check to see if you have an app called SuperUser (SU).
If you do then your device is rooted.
Other ways to check, which is more dificult because of you not being able to get WiFi access, is by downloading an app called Root Checker or a Terminal app.
Root checker is self explanitory as it does exactly what it says on the tin.
It will check to see if you have root access to your device and will tell you either way.
The terminal app will show a hash tag symbol (#) as soon as it is started.
This is also an indicator of root access.
Have a look in the WiFi/network settings for your device and see if it has been set up to use a proxy or VPN.
If it has then clear these settings and try to enable the WiFi again.
If this doesn't work then i would restore the device back to factory settings as it could be a software issue.
Failing that you could always upgrade the firmware to the new 4.4 KitKat which, if your device is rooted, will wipe root access out.
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
SERIAL NUMBER BLUEBEAM REVU X64 11.0
Android Phone ko root kaise kare,Mobile ko root ???? ??? ?? ?? ?? ?? ??? ???? ???? ??? ??. ?? ?? ?? ??? ???? ?? ??? ??????. Android phone ?? ???????? ?? ?? ??? ??????? ?? ??? ??, ?????phone ?? root???? ?? ???? ??? ???? ?? ??? ?? ????? ???. ???? ????android mobile ?? root???? ?? ????? ???? ???? ????? ?? ??? ?? ?????? ????? ???? ?? ?? ??? ???? ??? android phone ?? ?? ???? root ???? ???????? ??. ???? phone ?? root ????? ???? ??? ???? ????? ??? ??????? ???? phone ?? ??? ??? experiment ???? ???? ?? ?? ??? ??????? ???? phone ?? performance ?? ?? ?? ????? ???? ???? ??. ???????? technical ????? ????mobile ?? root???? ??? ???? ???? phone ?? ?? ???? ??? ?? ???? ?? ??????? ???????? ?? ????.
Android phone ?? root???? ?? ?????? ?? ???? ??? ?? ?????? ??, ???? ???? ??? ???? ??????? ?? " Android root ???? ??" ?? ??? ?? ????? ?? ???? ???. ???? phone ?? ?? ?? ????? ?? root ?? ???? ??? - ?? ????? ?? computer ?? ???????? ???? root ???? ?? ????? ????? ?? computer ?? ???????? ???? ???? root ????. ?? ???? phone ?? root ???? ????? ??? ?? ???? ??? computer ?? ?? ?? ???? ?? root ?? ???? ???, ????? ????? ??? computer ???? ?? ??android phone ?? root ???? ?? ???? ???? ????? ???? ??? ?? ?? ???? ??????? ???? ???? ??? ??Android phone ?? root ???? ???? ???? computer ???
Android Phone Ko Root Kaise kare?
?? ?? ???? ???? phone ?? computer ?? ??? ?? computer ?? ???? ???? root ???? ???? ?? ?? ???? ?? ???? ??? ??????? ????? ?? ???? phone ?? ????? ?? root ?? ???? ???. ???? ???? ?? ?????? ??root kaise kare.
Android Mobile Ko Root Kaise Kare without PC
Android ?? root ???? ?? ??? ???? computer ?? ????? ????? ?? ????? ????? ??? computer ???? ?? ?? ???? phone ?? root ???? ?? ??? android root applications ?? ???????? ?? ???? ???. ???? phone ?? root ???? ?? ??? ???? ???? applications internet ?? ????? ?? ?? ???? Google Play Store ?? ????? ?? ??? ???????. ?? ???? ????5 best Android rooting apps?? ???? ??? ??????? ????? ??? ?? ?? ???? phone ?? ????? ?? root ?? ??????.
Android Smartphone ?? Root Kaise Kare ????? ?? ???? ??? ????? ???????
???? phone ?? root ???? ?? ???? ???? 50 % ?? charge ???? ???? ???? rooting ?? process ?? ??? ???? mobile ?? battery ???? ? ?? ????.
???? phone ?? ??? data ?? files ???? contacts, music, photos, video, apps ??????? ?? root ???? ?? ???? backup ???? ?? ??? ???? ???? data lost ? ?? ????. ?? rooting ???? ?? ???? SD card ?? ?? phone ?? ????? ???.
???? ????? ?? apps ??? ?? ??? ?? ?? app download ?? ???? phone ?? storage ??? ?? install ?? ???. installation ?? ????? ???? ?? warning message ????? ????, application ?? install ???? ?? ??? ???? 'yes' option ?? ?? choose ???? ????.
???? ??? ???? phone ?? setting ??? ???? ???? 'Developer options' ?? ????? 'USB debugging' ?? option ?? click ???? ????.
5 Best Apps to Root Android Phone without PC
???? ?? Phone ?? root ???? ?? ?????? ??? ????? ????? ?? ????? ???? ???? ??? ?? phone ?? root ???? ?? ????? ????. ???? ?? ?? apps ?? ???? ??? ??? ???? ??? ????? ????? ?? phone ?? root ?? ???? ???.
1. KingRoot
KingRoot android phone ?? root ???? ?? ???? ??????? application ??. King ???? phone ??? rooting ?? process ?? ????? ?? ?? ???????? ??? ?? ??????? ??. ?? ??? ??? ?? devices ??? ???? ????? ??? ?? ??? ???? ??. Android phone ?? root ???? ?? ?? app ?? success rate ???? apps ?? ??????? ???? ?????? ??. ?? app ?? ?? ???? website ?? ??? Google play store ?? free ??? download ?? ???? ???. ?? install ???? ?? ??? ?? ???? phone ?? ???? computer ?? ????? ?? root ?? ???? ???.
2. FramaRoot
FramaRoot?? ?? ?????? app ?? ?? android phone ?? ????? ?? ?? click ??? root ???? ??? ?????? ???? ??. ?? app ?? ?? google play store ?? download ???? ?? ???? ??????? ?? ???? ????? ???? ??. ??? download ???? ?? ??? ???? ???? website ??? ???? ???? apk file ?? ?? free ??? download ?? ???? ???. Framaroot ?? ???????? app ?? ?? ???? ???????? ???? ?? ???? ??? ??. Framaroot ???? ???? devices ?? root ???? ??? ??? ??? ?? ?? ?? ???? ?? ?????? ???? ?? ?? ?? ??? ??? ?? devices ?? root ?? ???? ??.
3. TowelRoot
TowelRootapp ?? ???? ?? ????? rooting app ?? ?? ??? ?? ?? KitKat version ?? ??? ????? ??? ??. ?? app ?? ?? ?? click ??? ???? phone ?? root ?? ???? ?? ?? ???? device ?? restart ???? ?? ?? ????? ???? ????? ??. ?? ???? ?? ??? google play store ?? ?? ??? ???? official website ?? ?? app ?? free ??? download ?? ???????? ?? ???? ???.
4. vRoot
vRoot?? ????? software ?? ????? ???????? ???? ?????? ??? android phone ?? ???? computer ?? root ???? ?? ??? ???? ???? ??. ???? ???????? chinese developers ?? ???? ?? ?? ?? ???? ???? ?????? ??? ?????? ??. vRoot software 8000 ?? ?? ?????? android devices ?? support ???? ?? ?? ?????? ????? ?? ?? click ??? root ?? ???? ??.
5. Z4Root
Z4Root ?? ?? popular rooting app ?? Android phones ?? ???. ?? ?? light weight application ?? ?? ???? device ??? ???? ?? space ???? ??. ?? app ?? ?? ?????? free ??? play store ?? download ?? ???? ??? ?? ?? ???????? ???? ??? ?? ???? ???? ??. ?? app ???? phone ?? security ?? ?????? ????? ???? ?? ???? ???? device ??? ??? ?? virus ?? malware ?? ? ???. Z4Root ?? ???? ?? devices ?? support ???? ??. ?? app ??? root ???? ?? ??? ?? ??? ?? choices ???? ??? ?? ?? temporary rooting ?? ????? ?? permanent rooting. temporary rooting ???? ?? ???? phone ??? ??? ?? ??? ?? root ????? ?? ??? phone ?? restart ?? ???? ?? ?? unroot ?? ??????. ?? permanent rooting ???? ?? ???? phone permanently root ?? ??????.?? 5 apps ?? ???? computer ?? ???????? ?? ?? ???? Android phone ?? ????? ?? root ?? ???? ???. ?? apps ?? ???????? ???? phone ?? root ???? ?? ??? ?? ??? ???? ????. ???? ???????? ???? ???? ?? ???? ?? ?? ??? ?? ?????? ??? ???? phone root ?? ??????. ???? ??? ?? ???? ?? ???? phone ?? ??? features ?? ???? ???? security ?? ???????? ?? ???? ???. ??? ???? ???? ?? ??? ?? apps ???? ???? ??? ?? ?? ????? apps ?? ????????? phone ?? unroot?? ?? ???? ???.
?? ?? ??? ?? ??? ???? computer ?? android phone ?? root ???? ?? ???? ???, ?? ?? ?????? ?? computer ?? ??? phone ?? root ???? ????. ???? ???? ?? ?? ?? procedure ?? ???? follow ???? ????? ???? ??? ????? ??? ????? ?? ?? phone ?? root ???? ?? ???? ??? ????? ????? ????? ???? ??? ????? ???? ??.
PC ?? Root ???? ?????
Computer ?? ??? android phone ?? root ???? ?? ??? Internet ?? ???? ?? software ?????? ??? ?? ?? ?? ??? ?? KingoRoot software ???? ????? ??, ????? ?? ??? software ?? ??? ?? ???? phone ?? root ??????.
Step 1:???? ???? ?? ???? computer ??? KingoRootsoftware download ?? install ?? ??????.
Step 2:???? device ??? ???? USB debugging ?? option ?? tick ?? ?????? ?? ???? device ?? Settings ??? Developer options ??? ??? ??????.
Note:??? ???? device ?? setting ??? developer option ??? ???? ??? ?? ?? ???? setting ??? 'About phone' option ?? ???? 'Build Number' ?? ??? ??? click ???? ???? ??? ???? developer ?? option ????? ?????.
Step 3: Software ?? install ?? ???? ?? ??? ???? phone ?? USB ???? ?? ?????? computer ?? ??? connect ????. ?? ?? ??? ?? ????? ????? ?? ???? computer ??? internet ?? connection ????? ??.
Step 4:?? ??? phone computer ?? ??? connect ?? ?????? ?? ???? ?????? ?? ???? device ?? driver ???? computer ?? download ?? ??? ??. ???? driver ?? installation ???? ???? ?? ??? ???? computer ?? ??????? ?? ?? box ?????? ????? Root status No ???? ???? ????? ???? ?? ?? ??? ???? device rooted ???? ??. ???? ??? ??? box ?? ??? ???? ???? ROOT ?? option ?????? ?? ?? click ?? ??????. ?? process ?? ???? ???? ??? ???? ??? ?????.
Step 5: Rooting ?? process ???? ???? ?? ??? ???? finish ?? option ?????? ?? ?? click ?? ??????. ?? ???? phone root ?? ??????.
???? ???? ?? phone ?? root ???? ????? ??? ?? ????? ??? ?? ?? instructions ?? follow ???? ???? ?? ????? ?? ???? ???? ?? ???????? ???? phone ?? ???? ??? ?? ????? ?? ???? ??.
?? ??Android Phone ?? Root ???? ?????mobile ?? root ???? ??? without PC?? ???? ??? ???? ???????. ??? ?? ?? ???? phone ?? root ???? ????? ??? ?? ???? ?????? ?? ?????? ????? ?? ???? ??? ????? ?? ??????? ????? ?? ?????? ???? ??? ?? ????phone ?? root???? ?? ???? ??? ????? ??????. ??? ???? ??? ?? ???? ??root kaise kare??? ?? ??? ?????? ??? ??? ?? ???? ??? ????? ?? ?? ?? ???? comment ?? ?????? ??? ???? ???.
Sep 04, 2013 | Bluebeam Software Bluebeam PDF Revu...
5336-2524 wass having malware issues so i would appy fixes and if they did not solve the problem i would use the alt+f10 to do a factory restore. Now the feature is not only unavailable but the OS boots...
Instead of this to remove the malware, install the demo version of Quick Heal 2011, Update it, & scan you system with full, native, malware root-kit, etc, type of scan to solve the problem.
Jan 17, 2011 | Computers & Internet
Phone freeze unlock code
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
Jan 11, 2008 | Samsung SYNC SGH-A707 Cellular Phone
New dual phone "Unavailable"
read the manual,you have to put code from 1st base phone,
i do not remember the code,
Jan 01, 2008 | GE 25932 Cordless Phone
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
