What should I see before purchasing a sous vide?
  • 4 Answers
Sous vide is a culinary technique in which vacuum-sealed food is immersed in a water bath and cooked at a very precise, consistent temperature. Sous vide is look like a pressure cooker and works kind of like it. Before buying sous vide you should see the following feature:
Water Capacity
Capacity
Water Depth
Temperature Display
Temperature Range
Timer and many more like size, recipe to cook,etc.
Posted on Apr 22, 2017
3 Suggested Answers
sherylmsalda
  • 5 Answers
SOURCE: Where can I get the guide about sous vide?
Sous vide means under vacuum. It is a method of cooking certain foods, especially proteins, that is very gentle. It tends to produce very tender foods that can have amazing flavor profiles, depending on how they are seasoned prior to cooking. To get the detailed guide about sous vide you may click here.
Posted on Apr 21, 2017
sherylmsalda
  • 5 Answers
SOURCE: what are safety measure should one consider while using sous vide?
Sous vide can said as equipment used for cooking food in vacuum pressure. It is a kind of pressure cooker. In sous vide the food is cooked in water and the usage of oil is very less. Sous vide is mainly used for cooking beef, meat, fish, chicken, egg, vegetables. While using sous vide you have to be very careful as the water evaporates from it which can harm your body it you got in contact with it. But you can take precautions and to get aware about precaution you can view here.
How stable will the temperature will be of sous vide?sous
Sous vide is a equipment like a pressure cooker and cooks food in vacuum. It cooks food in vacuum steam and in water. In Sous vide food is cooked perfectly. In this the food not get burnt and does not loose its shape and taste.Temperature control is everything with sous vide cooking. A single degree change (1°C) in the water temperature can make a big difference to your cooking results. To get more details you can view here.
Apr 24, 2017 | The Computers & Internet
What is the need of sous vide?
Sous vide is a cooking technique used for making food in vacuum and cook food in water steam. It look like a pressure cooker. Water allows for the gradual cooking of food, and is a form of slow cooking. It can be very useful for the hostelers, working women, bachelors etc. To know more about the need you can click here.
What is the water capacity of sous vide?
Sous vide means under vacuum. It is a method of cooking certain foods, especially proteins, that is very gentle. It tends to produce very tender foods that can have amazing flavor profiles, depending on how they are seasoned prior to cooking. These vary between 5 liters and 120 liters, and the important thing to consider here is that there needs to be free space between the pouches of food that you are cooking for the correct circulation of the water. To have more details click here.
Apr 22, 2017 | The Computers & Internet
Apr 21, 2017 | The Computers & Internet
What are safety measure should one consider while using sous vide?
Apr 21, 2017 | Computers & Internet
Mettre sous tension Canon MF4450
j'ai un canon isensys MF4450 si j'essaie de lancer la photocopie l'?cran de l'imprimante m'affiche Mise sous tension
Feb 03, 2014 | Office Equipment & Supplies
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E210 remettre copieur sous tension, bagaimana ?
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E000 remettre copieur sous tension, bagaimana ?
Feb 07, 2013 | Canon NP 6650II Copier
Disk dur Magnavox H2160MW9 (160 Go)
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can gather all details. Sometimes, clicking on the adverts' by the side and bottom of each post might give you more details
May 27, 2012 | Magnavox H2160MW9 HDD Recorder
Bonjour je possede un ordinateur portable ACER ASPIRE 8930 G, je l ai passe sous windows seven Je voudrais reinstaller acer empowering technology que j avais lorsque j ai achete mon ordinateur et qu il...
Bonjour JosyAnne ,
Tu peux malheureusement faire une croix sur la version Windows 7 , Acer ne suit plus ?a sous cette version .
D?sol? ,
fanaudi .
May 09, 2011 | Computers & Internet
Bonjour pouvez vous me dire comment installer la tec sx4 en reseau sous windows xp
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
Feb 15, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
