My bravos spin cycle sounds like a jet plane taking off
SOURCE: spin cycle sounds like a
washer was under warrenty. called whirlpool and a service man camed to the house.i did have a wonerful response from your site and will call the appliance service man, when washer is no longer under warrenty,who called me yesterday and gave me lots of information. thank you!
Posted on Aug 02, 2008
  • 51 Answers
SOURCE: Noisy during spin cycle
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: washer sounds like it has rocks in it during spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 15, 2010
yalmer
  • 552 Answers
SOURCE: sounds like the inside is a jet plane while in
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
Posted on May 26, 2010
onthejob5130
  • 640 Answers
SOURCE: I have a whirlpool duet
wow,,we need to change the back tub bearing,,,if the unit sounds like a train coming in on a track. this happens when we dont use[ he ]detergent and oversudsing,,,but i have a btight spot the parts are under warranty,,just call the number on the label of the inside panel ..1800----------this is not in no way a job for a novoice...good luck any other question repost directly,,this is a pisture of were the sound maybe coming from.
Posted on Sep 09, 2011
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
The spin cycle sounds like a jet plane taking off. Any ideas as to what it could be?
Main bearing failure probably. Have a look underneath for an oil or rusty water stain around the cabinet... If it has, it may be an expensive repair and probably not worth fixing.
Dec 21, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
May 26, 2010 | LG WM-1832C Front Load Washer
Spin cycle is loud
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
