Question about Nikon Coolpix S1 Digital Camera
Card Cannot Be Used message?
Okay...my camera has been working just fine for about...a year? I'm not sure how long, but all of a sudden my memory card (which is a SanDisk 512 MB) isnt working. I put it in and the message "This Card Cannot Be Used" pops up on the screen. It wont let me format the card on my setup either...it wont let me select that option. Does anyone know the cause of or solution to this? Thanks so much :) Same problem, but the "Card Cannot Be Used" message didn't consistently appear. Often, turning the camera off and on again would do the trick. I recently reformatted the card in the past week to see if that would help, but now it is consistent showing that error message. I did start using a memory card reader on my PC at work, and I still use the camera dock on my Mac at home. Perhaps there is a problem there? Thanks!
  • glimer Mar 11, 2008
    Memory card cannot be read appeared when it had been working fine. I purchased a new SanDisk memory card, and the same error message appears.
  • Anonymous Jun 23, 2008
    Same problem - bought a PNY 2GB for my Nikon Coolpix 5900 about 5 weeks ago. I've been clicking away, uploaded all the pics, then re-formatted and now the chip is "corrupted" cannot be read by my laptop reader and when inserted into the camera, "cannot be read" - doh! I can't reformat on my laptop or on the camera (it just jumps over the format option when using the menu)
    Other SD cards still work fine in the camera though.
    Problem Solver:
  • 18 Answers
Just so you know, I have this problem also. Anyway, the only thing that works for me is to turn the camera on WITHOUT the card inserted, then insert the card. After this, it will let me take ONE photo, video, or noise clip before it gives me the error again (strangely enough, I just figured out this solution a couple hours ago as I was browsing a listing for a similarly infected camera on eBay).
For a permanent fix, the "cheap camera repair man" can repair both the menus and the error for 55 bucks on his website (DynamicCamera.com).
By the way, you only need one account, and one question.
Posted on Jan 06, 2008
HI! I have a one year old Lumix DMC-FS15 that I barely used for some personal photos, I bought a 4 GB SDHC memory card with it, it used to work just fine but now whenever I turn o the camera I message...
If the memory card works on your pc, chances are it is fine.
So you have two things to do : first backup on your computer any picture on your card.
Secondly put it back in the camera, go into the menu and find where to Format the card.
Once the card is formated by the camera try to take a picture to see if the problem is solved. If not, look through your camera menu, certainly under "memory setting" or something similar, then you will have an option to choose on wich memeory the pictures are recorded: the internal one or the card.
Make sure your 4gb card is selected. This shoul solve the issue.
Hope this helps.
May 27, 2011 | Panasonic Lumix DMC-TZ50 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
8GB CENTON SDHC memory card - class 4 - worked okay first day. Removed card to transfer pics to computer. Did fine. When inserted card back in camera JVC-PICSIO GC-FM2BU, got "Memory Card Error"...
Sounds like you forgot to use the "safely remove hardware" when you removed the card from the computer. Also, never format a card in a computer and then expect it to work in a camera. You can try to format it a few more times in the camera but if not successful, then you should think about getting an new card.
Feb 19, 2011 | Cameras
Memory card not read - cant use the camera at all
Use a separate card reader to download your pictures. Then, format the card in the camera.
Aug 26, 2009 | Polaroid T730 Digital Camera
Memory card error
If the card works on OTHER devices, and you've formatted the cards... the only conclusion you can really have is that it's a problem with the camera. Repair or replace.
Jul 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
No display; flash busy message is in view finder; new battery
I had the same problem, camera is only 5 months old and still under warrenty. I sent it into cannon for repair...mother board was shot...new board installed...have used the camera 2 times since getting it back...camera has died on me again...same problem. Have to send it back again! Don't recommend this camera to anyone!
Jun 23, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Memory card problem
wheather you check in computer repair shop is their any virus present in memory card? format your memory card! check virus is present in your computer or not! ?Try it!
Jul 11, 2008 | Nikon Coolpix S3 Digital Camera
Nikon S1 memory problem
Dec 15, 2007 | Nikon Coolpix S1 Digital Camera
If you've been using a 512mb sd card and it's worked your extremely lucky. the support was only designed to go to 256mb
Sep 20, 2006 | Nikon Coolpix 4100 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
149 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
