I have a sceptreflat screen hdtv that display a red picture Always
  • 3,828 Answers
TV user manual
in tv settings
a menu will have contrast brightness colour contrasts etc
if no better TV digital board faulty
side note . some people have eye problems from birth
colour TVs were set to full orange ..for my brothers
only then he could see the programs .... we had to suffer this till he left home
Posted on Apr 22, 2017
    New Friend:
Go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
2 Suggested Answers
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Screen problem
I have the same problem. rca 26lb30rqd. The red light is on (steady), and when I hit the power button, the blue light comes on for a second, then goes black, w/ no display. Before this happened, the display was extremely bright with ghosting. The picture was un-viewable. Did you every figure out the problem?
Mar 15, 2014 | RCA 26" LCD HDTV/DVD Combo 26LB30RQD - ON...
Screen turn to red hue and then back to normal
Not uncommon on this model as a lot issues with the red and most of them are caused by touchy master screen controls. The set has a black rectangular block with three screen and three focus controls, for whatever reasons the red screen control always seems to be the flaky one and usually a very tiny adjustment of that one does cure the problem.
Aug 27, 2012 | Hitachi 46F510 46" Projection HDTV
HP-R5072 50 in. HDTV Plasma Television: i have one red dot on plasma screen. it is always ...
Unless you see more red dots, this kind of "defect" is under specifications for this size of PDP, if you do not like it, the PDP module must be changed
May 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Dec 26, 2009 | LG 42LC2D 42 in. LCD HDTV
If its just half the screen then you need someone to 'carefully' look at the multi pin connector that connects to the display itself (on top of the screen inside) wriggling it may be all thats needed.
I've had bad connections causing different brightness levels before on JVc sets. Its not a DIY job to get to it!!
Nov 07, 2009 | JVC LT-37X688 37 in. LCD HDTV
My set has a RED background on all Inputs--DVD,Sat, Recorded DVR.....when playing a DVD a Bright Blue FBI screen is normal and the Bright Green Movie Rating Screen is Normal but the picture is RED....
I found a way to get into the service Display, 5 ,volume + and numbers come up---could figure out how to go to a Menu-----but somehow the picture is now perfect !
Anybody know why this fixed I said the RED background was on all input screens....the screen with no signal was a solid red instead of Black......
Jun 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convergence and lamp problems?
Well I hate to be the bearer of bad news but besides the convergence issues you have a bad red picture tube. Us techs refer to your problem as a 'floating grid' in the red picture tube. More bad news is that the tube is no longer availible. The only solution is to have a professional remove the red tube assembly and ship it off for rebuild. A company called Video Display does this work reasonably and I've sent several to them with great results. It takes about three weeks and the whole repair is very spendy, around $400 to $500. Sorry for the bad news.
Jun 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red shadow
bad connections on the converganc ics just solder them this will fix the problem if not replace them
Nov 03, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
