Cant start machine with time delay showing i didnt set the time delay it came up itself
My Whirlpool front load washer keeps resetting the delay start time. I don’t want any delay, but it keeps resetting itself to 45 minutes. Can you help?
could be the delay button is activating intermittently? try pressing it hard couple of times ...don't break the butoon :)
Nov 22, 2017 | Whirlpool Washing Machines
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Air king problem
. You probably have too many time delays in your system and check the timer set points. sometime some thermostat has a time delay and the unit itself has a circuit board time delay.
Sep 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Set brew delay
Assuming you're talking about the FT series with the "delay brew" button and the 24 hour analog as opposed to digital clock, it's simple.
First, you have to have your correct time set. This is simple just press the hour button and then the minute button until the correct time is showing. Be sure to look for the AM PM indicator to make sure you're getting the desired time set.
Then press the delay brew button and use the same hour and minute buttons until you get the desired time (again watch for am/pm)
That's it.
Jul 09, 2008 | Mr. Coffee FTXSS23GTF Coffee Maker
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
