Question about Sewing Machines
What size belt for Hobbylock HL603A - Sewing Machines
Price of a hobbylock 4842
Difficult to say. Supposedly original new price was ~$700
Pfaff Serger Overlock Hobbylock 4842 Specifications
However, if it is a used machine, so much is subjective based on physical and operating condition, the accessories included, desirability of the model, where it is located, etc.
PFAFF HOBBYLOCK 4842 SERGER 2 3 4 THREAD OVERLOCK FREE SHIPPING NO RESERVE...
Jan 10, 2017 | Sewing Machines
I have Hobbylock 774 what size of the niddles and brand I need to use
https://www.manualowl.com/p/Pfaff/hobbylock-774/Manual/184560
Jul 12, 2015 | Sewing Machines
Pfaff 795 hobbylock manual
There is eBay item 160737677765 with this manual I found for you.2_15_2012_2_36_56_pm.jpg
Feb 15, 2012 | Sewing Machines
I need a manual for a Pffaf Hobbylock 4870.
http://servicemanualrepairs.com/book/pfaff-hobbylock-4870-instruction-manual/
Jan 11, 2012 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Where can I find needles for my hobbylock 794? The machine says # DBX1 no. 9-16.
I have a Hobbylock 797 and that takes standard 130/705H sizes 11-14
Feb 22, 2009 | PfaFF Quilt & Craft Pro 7530
Pfaff Hobbylock 788 Serger won't work
Does it still make noise? Maybe it needs a new belt or just some oil?
Jan 10, 2009 | Sewing Machines
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
