How to put it on quick wash - Washing Machines
The quick wash takes over an hour any suggestions how to make it quicker?
The manual says wash number 5 takes 60 minutes the only shorter cycles are numbers 9 & 10 which take 55 minutes but they are cooler washes for wool and silk with a spin speed of 800rpm the number 5 has a spin speed of 1400rpm.
Apr 26, 2015 | Hotpoint Aquarius WDL540P White 60 cm...
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
My duffel bag is dusty inside is it safe to put it in the washing machine?
I have never put a duffel bag in the washing machine. Usually my bags just get dusty inside so I just wipe it out with a damp cloth and let it sit in the sun to air dry. If it really needs to get cleaned you should check with the maker of the bag before putting it in the washing machine.
Sep 17, 2013 | Luggage & Travel
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine says its blocked
take the block off it and it wil work just fine.
May 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing machine fjs 1025 w can you identify my problem
Put on the machine. Try depressing "end of cycle" button for over 5 seconds. Turn down the temperature knob first. Let me know result.
Dec 27, 2007 | Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
