Question about Simpson Washing Machines
Hi do you have any documentation on how to remove the head panel of a Simpson EZIset 950 washing machine. I believe the fuse has blown
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
hattonhall
  • 349 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
  • 159 Answers
SOURCE: simpson eziset 950 wont turn on
Hi there.There is a fuse inside the head panel.the fuse is a glass type about 3.5 amp.you can normally get these from an electronics shop such as **** smith or Tandy Electronics.Make sure the plug is out.the fuse is in the green circuit board.
Posted on Jun 01, 2010
  • 59 Answers
SOURCE: my simpson eziset 950 washing machine is leaking
OK the trasnsinssion will be full of water and the contents are being forced past the lower oil seal during agitation. You might enwuire about a new transmission or get a new machine....not the best news but if you went for a stronger make you could own it for twenty years......no joke. www.thewashingmachineman.webs.com ask tony
Posted on Sep 07, 2010
Daniel S
  • 4323 Answers
SOURCE: Can anyone please tell me
Hi
FL means flood and this error is caused to due to blocked drain pump or the drain pump itself going bad and should be replaced. It can also be the result of you turning the water level knob back to a level lower than the level of water already in the wash bowl, whilst the machine is in pause mode. Press START/PAUSE to continue the wash, or turn the water level knob to a high level to clear the fault, if the error returns then get the washer serviced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 04, 2011
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 950 wont turn on''
May 31, 2010 | Washing Machines
My simpson eziset 550 washing machine just stopped during a rinse cycle all the electrics are out, can i fix this myself?
hope this helps
Feb 24, 2010 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Vernon Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
