Question about Hoover Washing Machines
SOLVED: Error code E12 on hoover washer dryer wdyn 9646 pg The problem is in the thermostat. Try pumping slightly on the thermostat unlock. I have solved it so. If it does not work replace it
jsrock516
  • 5911 Answers
SOURCE: F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Posted on Sep 11, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Furnace not kicking on when thermostat calls for heat
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Jan 10, 2010
SOURCE: I'm getting error code 2037
You may need to update your iTunes, or reinstall, make sure you have the latest software, if that does not work, go online to www.apple.com to talk to someone just to make sure nothing is going wrong on their end. It could also be your account, make sure you credit card information is up to date. It will also help knowing what that error code means, so if you do have to contact apple have that error code handy.
Posted on Dec 12, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
SOURCE: error code E11 on hoover
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
My washing has a E12 code on it.
I appreciate your inquiry, friend!
From what you have described your Electrolux washer is displaying an error code of "E12". An "E12" error code stands for a non-fatal reading or writing to the memory. This can be cleared with a reset and you can do that by unplugging the power cord for roughly ten minutes. If this does not resolve your issue it could be a possible problem with your control panel and that may need to be replaced. I hope this information is helpful. -Matt
Mar 15, 2015 | Electrolux Washing Machines
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
I have an error code E07 on my Hoover WDYN 854dB which results in me not being able to open the door after a wash cycle any idea how to open the door
make sure its drained 1st even drop hose to ground level which will gravity drain then door should open, could be blocked filter.
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
Hoover wdyn 9666pg-80 error code E11
I fixed ours! here is a video of how i did it, it shows where the wire snaps and what part the wire connects to:
May 11, 2012 | Hoover Washing Machines
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
HC error code 110.27087603
Washer...check the pump unit and your manual...should have a code listing in there
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Hoover wdm120
more than likely that yor pump hasnt let all the water out try getting your outlet hose from under the sink and place into a bucket low to the ground if water comes out than your door will open after a short while if water does come out than make sure your pump or drain hose is not slightly blocked if not then your pump is on its way out also if water doesnt come out of drain hose than take it off at the pump if it comes out then,then your hose is blocked m8
Aug 20, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
213 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
