Question about Simpson Washing Machines
Hi Do you have any documentation on how to remove the head panel of a Simpson eziset 950. Suspect fuse has blown
hattonhall
  • 349 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
  • 343 Answers
SOURCE: Hi, my Simpson eziset 605 doesn't hold any water.
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Posted on Apr 20, 2010
  • 159 Answers
SOURCE: simpson eziset 950 wont turn on
Hi there.There is a fuse inside the head panel.the fuse is a glass type about 3.5 amp.you can normally get these from an electronics shop such as **** smith or Tandy Electronics.Make sure the plug is out.the fuse is in the green circuit board.
Posted on Jun 01, 2010
SOURCE: Hi, My Simpson eziset 550
hi belinda,we have had the same problem over and over,even the technician didnt know what the problem was and we went and are still going through frustration..dont call a technician..take the back metal sheet off and there is a small plastic hose that connects onto a a small outlet on the right hand side bottomright of tub,it comes off and the sensor for water cutoff stuffs up,we tried to superglue and reclamp it but it still comes off through the vibrations,it is just trial it ourselves..so much for profesional technicians..and error,finding the best way to secure it..but thats where your problem comes from..
Posted on Oct 26, 2010
  • 6277 Answers
SOURCE: Simpson eziset 950 washing machine
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
My Simpson 9kg was her won't turn on
Hi. Thanks for your question. For assistance on simpson 9kg for Eziset 950 you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 26, 2018 | Cars & Trucks
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 950 wont turn on''
May 31, 2010 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
