Question about Soundstream Car Audio & Video
I need a replacement dash mount bass/gain control for the soundstream XXX6500d
2 Suggested Answers
madbodger
  • 11 Answers
SOURCE: bass control knob broke off, what di I do?
You don't list the brand, but you can buy replacement knobs for many brands from http://www.pacparts.com/. Note that while the parts are very reasonably priced, you may end up paying $12 shipping for a $1 knob. If it doesn't have to be a matching knob, you may be able to find one that will fit on a radio at a yard sale or junk yard. Another possibility is to try Radio Shack. http://www.radioshack.com/search/index.jsp?kwCatId=&kw=knob&origkw=knob&sr=1
Posted on Aug 17, 2009
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Inputs:
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Controls:
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Thanks
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
The gain is broken, the bass on my sub go in and
the gain pot needs to be replaced as the audio signal goes through it
May 05, 2010 | Hifonics BX1500D Car Audio Amplifier
Power to rubicon 404 no sound 4 channels of 2-way high pass
Check RCA,s at the back of the head deck, make sure sub is set to low bass frequency, make sure gain is turned up on the amp and head deck has subwoofer enabled and bass on. If you are powering speakers make sure the balance on the head deck is set to 0. Make sure it's wired up properly.
Jul 22, 2009 | Soundstream XTA240.2 Car Audio Amplifier
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Tuning 8302 amp
The amount of power that youre going to run on those 5.25s might indicate that you need to turn the crossover to a higher cutoff frequency because they gonna want to kick pretty hard if your set too low - Sounds like you got it under control though flip it to high-pass(HP) and see how it does at around 100 HZ cutoff- be sure to turn off any bass boost on the amp though too- Let me know how them soundstream mids do- I have a set of subs that kick *** but i never have heard anything about their mids-good luck
Oct 18, 2008 | MTX Thunder 8302 Car Audio Amplifier
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Car Audio & Video Logo
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
