Question about Hard Computers & Internet
Initialized tyros 3 keyboard held end key no lights came on having just deleted hard drive.i,
5 Suggested Answers
  • 5603 Answers
SOURCE: putting on Computer what I have on Memory stick
Make sure you are in the song mode so you transfer just the song and not all the other stuff. Copy a song in the song mode to your USB stick, then read it on the PC. To burn it as DATA (MIDI data is data) you must use a burning program like Nero...
If you are trying to make an audio CD that is a different story as you need to convert the MIDI file to an audio format such as MP3 or WAV before burning and AUDIO CD.
Posted on Jun 25, 2010
SOURCE: I have forgotten my security
i forget my securitycoad 1208
Posted on Jan 29, 2011
  • 23 Answers
SOURCE: I need to replace the 3 1/2" floppy disc drive for
This should be easy enough to find with a web search on your part number... but it is very likely that almost any floppy drive will work, as long as it mounts in your location.
Posted on May 18, 2011
  • 7 Answers
SOURCE: Samsung Laptop Keyboard Problem All peripheral keys are non responsive.
Given test u have done likely to be ribbon cable connecting graphic display card/port on mboard to screen. May well have caused bluescreen. Happens if laptop frequently opened/closed causing wear between base/ lid which can then short
Posted on Jan 18, 2014
Flashing lights with no fans, held power button down & now only red lights (internet adapter, volume button) & fans are working why? help?
this sounds like a hardware or driver issue
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
or you might try
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
May 10, 2012 | HP Pavilion dv7-1130us laptop
Delete key on laptop not functioning
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard, if no change! there is a device drive issue, do a system restore of your computer back to an earlier time before this happened.
Mar 11, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
I want to add orchestral backing to song
Build the orchestral as a MIDI file and then merge your song and send back to the Tyros to perform it. Building on an external machine you will find is easier than trying to do it all on the Tyros.
Sep 15, 2011 | Yamaha Tyros4 61-Key Arranger Workstation...
How do I download a software update 1.02 for tyros 4 keyboard
go to the website of tyros and download the update for your keyboard.
http://download.yamaha.com/top/?site=usa.yamaha.com&language=en
then follow the instructions, you have to connect your keyboard to your computer.
Mar 02, 2011 | Computers & Internet
I have to format a cruzer sandisk on my tyros 2 keyboard but i do not know how to.
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jan 24, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can i delete folders from my wd hard drive (500)
You can delete the folders from your hard drive by
**To select any folder just Left click once on the folder**
1. Select the folder press delete button from keyboard.
2. Select the folder right click it in it you will see delete option just click delete.
3. All the 2 above ways will delete the folder but it send the deleted folder in your recycle bin from there you have delete them further by the same methods i told you above or by right clicking recycle bin icon in it you see empty recycle bin.
4. If you want to delete the folder permanently without sending it to recycle bin. Just select the folder and press shift+delete keys. Then a dialog box appears to conform it select yes and thats it.
You can contact me or thanks me on my email id ejaz89@live.com
Aug 05, 2010 | Western Digital My Book Essential Edition...
My Tyros 2 plays additional notes when I play chords particularly in C, G and E-Flat scales. The challenge is that I am living in the Caribbean and there are nor official keyboard technicians nearby. I can...
This is not something that spare parts would likely be needed for.
The first thing to determine is if in the piano mode that the unit first comes up in do you get this problem. If you do not, the UNIT is likely OK electronically. If you DO get the problem as a plain piano at start up, then one or more disconnect diodes (small 1N4148) are probably shorted. This is VERY uncommon occurence. These diodes are on the contact boards of the keys themselves. Contamination of metal such as a paper clip or metal shard could cause the same thing.
The Tyros II has MANY features and a lot of these create layers that fire other notes when using styles as part of the stylle rhythm.
The keyboard split features that allow the keyboard to act as three seperate ones can lead one to think there is a problem.
I have two Tyros I and one Tyros II and have worked on all of them as they were purchased as damaged and non-functioning. I have schematics on CD and those are available from Yamaha America parts dept in California. They are copyrighted but they will sell you the CD with schematics, etc. for about $15.
I can help you troubleshoot the problem if it really is a problem. The first thing is to see if problem exists in the piano mode at startup. If it does, then try each note in combination to establish a pattern. If a disconnect diode is shorted, you will find certain notes interact. You need to find which are OK and which causes problems... Defining the keys as problems in chords does not help as we need key numbers such as C3 or F#4. Do the searches ONLY using two keys at a time as a matrix problem cannot be diagnosed doing three at a time or more.
Aug 01, 2010 | Music
Say's it needs to initialize and comes up with eisa.
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
Putting on Computer what I have on Memory stick. I have saved songs from a Tyros 3 Keyboard and have difficulty putting it on Computer so that I can burn it on a CD...H E L P
Oct 19, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Computers & Internet Logo
65 people viewed this question
Top Hard Computers & Internet Experts
john smith
Nyte_Ryder
gbob59
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
