Question about Hoover Washing Machines
I have a 1600AAA Super Silent Hoover washing machine and i want to use the very hot wash but without the pre wash for clothes dying purposes. How do i do this please?
  • 641 Answers
SOURCE: smell from tub
Does it the first time you have this bad smell and for how long do you use this machine in its cuurent location ? Try to run an empty machine cycle with a quart of vinegar to clean the tub and pump. Let me know if it solve your problem ? Good luck !
Posted on May 28, 2006
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
  • 9 Answers
SOURCE: how to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Posted on Jul 19, 2009
beltronic205
  • 1474 Answers
SOURCE: I have a Hoover 750L washing machine and it is not
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
Posted on Mar 31, 2010
Washing machine too hot
Turn down temp on your home water heater.
Apr 22, 2010 | Hoover HW160M Front Load Washer / Dryer
Tip
Hoover 1600aaa
Just a basic one before you phone your washing machine engineer on the hoover the pump does seem to clog up very easily basic problems to which you wouldnt even guess what the problem can be.Your pump maybe blocked hair bobbles,money even pet hair can cause this.
problems:
machine wont drain or spin
the best way to fix this is too always pull down the front flap underneath the drum
Makesure you ave a tray to accomadate all the water in there if it is blocked there will be a lot anything that could be blocking it will be there.
Once any blockage is removed put the plug back in and test to see if the wash will work if it does problem solved and you just saved yourself £50 plus
on Feb 27, 2010 | Washing Machines
My hoover hpe236. The lights flash intermittently
Hello
Maybe the wire to the light has a loose connection or your bulb may need to be replaced.
ilona
Aug 02, 2017 | Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Water Accumulating in Washing Machine Drum
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Mar 04, 2018 | Hoover Washing Machines
Smell from tub
May 27, 2006 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
24 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
