Question about Alpine Car Audio & Video
Cd play plays no sound but tuner has sound on alpine cda-9856
SOURCE: radio sound but NO cd or ipod sound
its not the radio. you have an amplified system in your vehicle and you hooked up the power antenna (blue wire from the radio) and the amp is only energized during AM/FM playback. disconnect the blue wire and connect the blue/white to the car's harness to energize the amp during ipod and cd playback
Posted on May 26, 2008
  • 8 Answers
SOURCE: wont accept cd
I JUST OPENED THE BACK CASING AND FOUND A WHITE OBJECT & SPRING LAYING AROUND , AS SOON AS I FIGURE IT OUT I'LL POST A SOLUTION
Posted on Jun 29, 2008
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
  • 126 Answers
SOURCE: i need to know how to reset the time and date on
all stereos have a PIN button
press it and this should reset the unit
or
disconecct the power
Posted on Dec 07, 2010
brandonbmw
  • 31 Answers
SOURCE: I have installed my Alpine
When your leasing to CD make sure that your EQ is still set up the same as when its in Tuner mode.
Posted on Mar 12, 2011
Iphone mode
For most alpine unit there is a separate unit to control the iPhone and is very easy is just a plug and play connection. Find a compatible unit for your deck.
Nov 07, 2013 | Alpine CDA-9856 CD Player
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
What is the color code for sub woofer control on alpine cda-9856 wiring?
Well I found out on Pages 34 & 35 of the following Alpine manual:
http://vault.alpine-usa.com/products/documents/OM%20CDA-9856.PDF
The Remote / Amplifier Turn On is a Blue/White wire.
May 15, 2010 | Alpine CDA-9856 CD Player
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Jan 16, 2009 | Alpine CDA-9856 CD Player
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
Sep 03, 2008 | Alpine CDA-9856 CD Player
CDA-9851R
call tech support
Mar 11, 2008 | Alpine CDA-9856 CD Player
Alpine CDA-9856
Do you have to run in AUX to get XM Radio? Your receiver and unit sound like its ok. This could be a problem with your provider. Contact your provider and their tech dept can help you organise a solution. Is your radio, XM ready?
Mar 09, 2008 | Alpine CDA-9856 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Alpine CDA-9856. Search button for IPod will not bring up menu
I have the same problem with a CDE-9870R and my iPod. I tried my daughter's iPod, and it works. I did not search any further, but it may come from the iPod software version. Mine is more up-to-date than hers (5th generation iPod 1.1.2 2006-06-28 update).
Mar 26, 2007 | Alpine CDA-9856 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
