Question about Pool Pump Pool & Spa
E series 230 pool pump will not run after i put it back together
    Top Expert:
  • Pool Pump Master
  • 7,897 Answers
Check reconstruction make sure correctly assembled if ok maybe wet end distorted if overheated by no water or bad motor
Posted on Dec 07, 2017
  • 61 Answers
SOURCE: Pool pump will not fill back up
It sounds like you are sucking air into the pump. Make sure strainer baskets and pump baskets are clear, and the valves are in the right position. Also check the water level in the pool, and make sure that the pump is not sucking the skimmer dry. Next try lubricating the gasket on the pump lid, or if it is in bad shape (flattened/cracking) replace it. If this does not solve the problem put silicone around the inlet to the pump (silicone is a temporary fix that could last days or months--for best results replumb with teflon tape and sealant). If all that fails you could have debris stuck in the impeller.
Posted on Apr 05, 2009
  • 308 Answers
SOURCE: pool pump burned out - Wayne WIP150
You can go and buy a new motor, but that is about it...short of having the motor rewound, but I think you would find this to be a more costly option.
Posted on Jul 08, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: i'd like to know how to change a 115/230 volt pool...
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
Posted on May 29, 2010
  • 70 Answers
SOURCE: I have a kenmore 70
check the float
Posted on Aug 16, 2010
john224
  • 1378 Answers
SOURCE: NEED TO SEE A PICTURE ON HOW TO PUT THE POOL PUMP
Try the manual, page 13, found here...
John
Posted on Mar 10, 2011
I cant see the way to change 115/230 starite pool pump 1.5 hp
look on the motor ID plate it has a diagram how to set voltage
Jun 30, 2012 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Water is running out the waste valve when the pump is running and filter is set on filter. How can I get this to stop?
You may need to disassemble the top of the multivalve, make sure the handle is 180* to the "Cam"
Jun 14, 2012 | Hayward SAND FILTER, PRO SERIES
I just replaced the latreals and sand , now the water is running out of the waste while it is on filter ?
It sounds like your pool filters spider gasket might be bad or might now have been installed right when you put the filter back together. You will need to fix it or replace it if water is coming from the waste while the filter is running.
Jul 01, 2011 | Hayward SAND FILTER, PRO SERIES
Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Jul 08, 2010 | Hayward TRISTAR INGROUND POOL PUMP - 2 HP...
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
How do i change the sand in the hayward e1001542s
we have changed the sand in our filter but now we cant get the back wash to work we have a davey tagelus 230 i need a diagraham to show how to put the muliti flow value on again
Oct 26, 2008 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
Top Pool Pump Pool & Spa Experts
Lawrence Oravetz
john h
Steve Buck
Level 1 Expert
Are you a Pool Pump Pool and Spa Expert? Answer questions, earn points and help others
