Question about Makita JR3050T Recipro Saw 9 Amp
Wiring varible speed swith for a Makita JR3000V reciporcating saw
I bought a variable speed switch for the Makita JR3000V
but it wired differently then the original switch. The switch has four wire connections. The wring connections are labeled: load/bi-ristor, load/125 VAC, line/6A, and one labeled just line. I am assuming the load connections are for the power cord and the lines are for the wires going to the motor. Does it make a difference which lead is connected to each side of the switch?
  • 2,176 Answers
The replacement switch, is it Makita and was it a direct replacement for the original part? That could make a difference. I looked at the schematics for this tool and they do not furnish the wiring codes but I think you are on the right track. To make sure though I would call Makitas tech support people at 1-800-4625482 and have a wiring explosion sent to you. Let me know if you still need more help and I will contact them or call a local dealer that I know.
Posted on Jul 26, 2009
One of the small(not power wires) pulled out from motor. where does it reatach? the one on the bottom of the motor. Makita jr3000v
there is a transparant or white wire in the middle between 2 wires that comes on the power wires on the switch and that middle wire on the supression capacitor goes into an small hole in the electric field for radio suppression .
Jul 15, 2016 | Makita Jr3000v Reciprocating Sawzall
How to changing switch
White and black from cord go to line (doesn't matter what side it's not polarity sensitive) and the field wires (the two remaining black wires) go to the load. Again it doesn't matter what side.
Jul 27, 2014 | Makita Switch For Jr3000v Reciprocating...
Makita recipro saw makes a clicking noise when I try and run it. Model 4390D
There is a problem in the drive shaft or teeth open it and look all the parts and also the motorhouse for very little broken tooth pieces most its laying in the grease.
Makita 4390D Reciprocating Saw Parts
Oct 13, 2013 | Makita JR3000V RECIPRO SAW
Loud tapping noise from makita sawzall jr 3000v
It sounds like one of the teeth on the main gear is missing. Parts list @ Makita.com or call Makita at 1-800-462-5482
Dec 29, 2012 | Makita Jr3000v Reciprocating Saws
How do i replace the gears on a makita reciprocating saw
Expensive job. You have to replace the armature and the gear which retails around 110 pound alone you would be better buying a new one unfortunately.
Nov 06, 2012 | Makita Jr3000v Reciprocating Sawzall
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
Blade too thick got stuck
lock the blade in a vise or grip it tightly and with the clamp open TAP on the shoe to pull the saw away from the blade. Use gloves and unplug the tool before attempting.
Jan 05, 2012 | Makita JR3030T Variable Speed...
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
I need wiring details for makita jig saw 4301bv
I have a little bad news for you. Makita doesn't furnish their wiring schematics online and I checked a couple other sites and nothing but you can call 1-800-4625482 that is their free technical support line and they can get you one.
Feb 20, 2009 | Makita Saws
Makita JR3050T Recipro Saw  9 Amp Logo
1,547 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
