Question about Air Tools & Compressors
How to get air class 1:2:1 by using sullair compressor?
3 Suggested Answers
ollie reece
  • 1167 Answers
SOURCE: I have a Sullair 185 air compressor. The engine
your not return balve is stuck open or your valves are sticking the pressure from the tank is going back to the pump so when the compressor goes on the compress stroke its very hard as it has to open the valve with pressure behind it its hard to explaing buddy but on the tank you wil see anon return valve from the pump unscrew it and inside is a rubber with a spring turn the rubber around and try this if doesnt work you need to inspect the valves (if sticking) good luck
Posted on Sep 02, 2009
  • 10 Answers
SOURCE: I have a 450 sullair portable air compressor that
Along with the oil air separators, there is a filter in the oil reservoir tank that needs to be changed every six months. You should contact a qualified air compressor shop for regular service. If the filter is not installed correctly, injury or death may occur. Pool tile cleaning uses the same compressors.
Posted on Jun 17, 2011
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
Type of d a torque fluid used in sullair 185Q air compressor
contact sullair for this as the correct oil is essential for good performance. You may find the information on the web under sullair compressors.
Jul 21, 2013 | Cars & Trucks
Sullair compressor
check condition of air filters and dryer filters.
May 16, 2013 | Sullair 350 Air Compressor; Sullair...
I need a workshop manual for sullair electric compressor model DXN20AC 92KW
You can contact your local Sullair distributor. Many of them will email a copy if it is available. You can find your dealer by going to Sullairs web site and on the industrial tab, look for reps.
Sep 07, 2011 | Air Tools & Compressors
I have a sullair 185 engine dies and light blinks one and says compressor over heating what causes the compressor to overheat
Hi, my name is John. Welcome to FixYa. Low oil level, and poor air circulation. Thanks for choosing FixYa....John
Nov 22, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
LOOKING FOR WIRING DIAGRAM FOR A SULLAIR 750DP ROTARY SCREW COMPRESSOR. MANUFACTURED IN 1982 FOR U.S.N.
I would contact Sullair factory, they have a great support group that I have contacted not as a Sullair distributor and the still provided me with the information I requested. have the model and serial number when you call them. there number is 1-888-775-1604
Feb 03, 2010 | Air Tools & Compressors
We have a Sullair 100 GPQ lubricant recommendation
hi mate ask the manufacturers as different compressor take different oils like im a compressed air engineer and i use rcr 32 and rcr 46 but i have never had to work on a sullair as there not common in our area
Jul 30, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
