Do you have a repair kit that includes items including brushes, bearings an d any other replacable parts?
    Top Expert:
  • Washing Mach... Master
  • 50,514 Answers
No
fixya doesn't do spare parts
Posted on Apr 22, 2017
How to repair bosh 11316evs
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Apr 15, 2014 | Bosch SDS - max Demolition Hammer 11316EVS
What size clutch fits a 2003 gti 1.8t?
comparebanner.jpg Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31668 Warranty: Limited Lifetime Application: With 6 speed transmission
9 1/2" disc outside diameter
Notes: Spline inside diameter 1 5/16". Spline count 23.
Add More Items to Compare Add More Items to Compare Price: $316.99
STORE PICK UP SPECIAL ORDER SHIP TO HOME AVAILABLEADD TO CART Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31620FW Warranty: Limited Lifetime Application: With 5 speed transmission
8 7/8" disc outside diameter
Notes: Flywheel Included. Spline inside diameter 7/8". Spline count 28.
May 26, 2012 | Volkswagen GTI Cars & Trucks
CAN YOU REPLACE BRUSHES
Sure can! Chances are if you need brushes, you should do a clean up of the motor as well. If there has been no water intrusion then the job is fairly easy, if water has gotten into the motor you'll need to spend some time and elbow grease cleaning it out . Always replace the seals, they come in a kit and are inexpensive. At a repair shop average repair bill shouldn't be more than $70-90 for this including parts. Parts can be purchased here: www.mikesreelrepair.com
Jun 13, 2011 | Minn Kota Maxxum 70 Freshwater Bow Mount...
How much and what type of lube do i put in the area where the piston and crankshaft are located?
Best practice is to purchase service kit part # 1617000050 . It is available from several outlets including link below. The kit includes items that need to be replaced at time of lubrication.
If you do not want to purchase the kit then use Bosch 1615430015 Hammer Grease 15oz
Mar 08, 2011 | Bosch Brute Breaker Hammer 11304
Drum has sagged in front ,bad rollers or drum support? motor wont turn drum enless i kinda lift front of drum .i dont have the manuel.Dave
Hi and welcome to FixYa. I am Kelly. If you can provide me with a mmake and model number I can tell you exactly what parts to order and change including the source to correct the problem you describe.
These parts are in most cases are:
1. The drum bearing ring: (not always bad)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Bearing-ring-for-front-support-item-number-AP2996731.aspx
2. The front drum (Replace)seal: http://www.appliancepartspros.com/part_details.aspx?part_id=3131525
3. The rear drum seal: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
4. Roller kit and belt: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-repair-kit--29-inch-large-capacity-models--item-number-AP3131942.aspx
These are the most common failures. I would recommend ordering and replacing all parts 2 - 4. Doing this will ensure your dryer will last for a long time trouble free. (tumbling)
See this manual for general help: (Important)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Dryers
How do I remove top loading whirlpool agitator to get at the ''centrifugal dogs'' that grab
If you need to replace the agitator dogs, the following link explains how:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the replacement kit is included. For a little more, you can purchase the entire cam replacement kit (which includes the dogs, the cam, the cam seal and thrust bearing).
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites I've listed also include exploded view parts illustrations that can assist you with locating and properly identifying the parts you need.
If you have any questions about this repair, please post back with you MODEL NUMBER and let me know. I hope this helps you.
Mar 09, 2010 | Washing Machines
Top of aggitator does not turn.
This problem is commonly caused by worn agitator dogs on the agitator cam assembly. This is a very simple and inexpensive repair. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3138838 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. The parts I have referenced are listed as items 9 and 10 under the Agitator Parts section. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 06, 2009 | Whirlpool GSW9800PW Washer
Agitater dogs on la5558xt
The agitator on this model washer has a split design. The lower portion is the agitator, while the upper portion is called the auger. Under the auger is a cam drive. The cam acts as a clutching mechanism that drives the auger when the agitator moves. The cam has small plastic teeth called "dogs" that commonly wear out causing the auger to slip. The following link explains how to replace them:
The part number is included in the link and can be purchased at appliancepartspros.com for about $5. For a little more you purchase the entire cam replacement kit which includes the cam, bearing, any seals, and the dogs for about $11. You can view these items at the website as items 19 and 18, respectively, under the "Agitator, Basket and Tub" heading.
This is a very simple repair that should only take about 30 minutes. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 15, 2009 | Washing Machines
Bust alternator for a diesel Grand Vitara 2005 2.0 TD RHW Peugeot engine
The cost of many of these units is quite high, compared to what they used to be. Still, the choice of new, reman, or even one from a boneyard is your choice!
Consider that a new unit is just that.eEverything including the case is new. A remanufactured unit is "iffy" and depends upon the quality standards or the manufacturer... Some only replace failed items, clean it up and let it fly... Better shops, replace not only failed items but items which are slightly worn or prone to failure. (a good rebuild includes brushes, regulator, end bearings, diodes and anything else they deem necessary) When buying a "boneyard" part, try to get one with low miles, preferably one that looks as if it was recently replaced, or one that was in the latest year vehicle that fits your application. As I said the choice is yours!!!
Jul 28, 2008 | 2005 Suzuki Grand Vitara
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
