Question about Bose Audio Players & Recorders
Wires code for Bose amp assy 28060 2y920 - Bose Audio Players & Recorders
Reconnecting/retiring Bose speaker cones. Inside speaker I have four coloured wires....Red,Black, Green & Orange....which connectors do they attach to on the speaker cone?
Since you posted this in cars and trucks I assume this is a bose car system. Most bose auto systems have the amp physically attached to the individual speakers. This means each speaker needs the following wires +12v, 12v ground, + signal and - signal. It also means that the head unit cannot directly drive a non bose speaker. If you are replacing the speakers and bose radio the best thing to do is to run new speaker wires. You can reuse the factory ones if you can identify which ones are what...and that may be a pain. If the bose amps are ok and you want to replace the speaker you would need to leave them connected and wire the new speaker to the wires on the bose speaker that come from the bose amp. Depending on the specific bose system there may be an actual wire that runs to the speaker from the amp but on others the amp is directly connected to the voice coil leads of the bose speaker.
Oct 13, 2016 | Cars & Trucks
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
93 cadillac speakers have 2 wires upgrading to delco/bose from a 89 cad fleetwood with 4 wires to each speaker.amps are in each speaker.are 2 wires for power if so from where
the bose system had power(two wires) and low level signal(other two wires)going to each speaker. The power came from the pre-amp mounted in the trunk.
Oct 28, 2009 | Car Audio & Video
Bose amp in a 1999 yukon denali
To isolate what speaker is what set of wires, I always use a AA 1.5V battery and touch one end of each set of wires on each end of the battery, and you'll hear a crackle from the speaker they belong to, then I label it. Can use AA,AAA,A,C,D battery doesn't matter as long as 1.5v. Don't know if that's what you were looking for or not. Old trick from years ago.
Jun 05, 2009 | 2004 Nissan XTerra
2008 Suburban LTZ with Bose Find Subwoofer wires 4 HiLow
It seems that your problem is actally the amp you are trying to use, many have either a switch or pontiameter to allow the speakers you are running either to play mid-range or low-range (sub) take a closer look at your amp that you are using
Apr 06, 2009 | 2008 Chevrolet Suburban
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
Radio wiring
yes, you'll need to purchase a "line level converter" to change the speaker connections to RCA connections. Or buy an amp that accepts speaker level inputs and extend the wires to the amp. If you have Bose system (says "Bose" on speakers), this will be different since you already have a factory amp
Aug 22, 2008 | 2000 Pontiac Grand Prix
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
95 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
