Question about Craftsman Garden
Craftsman lawn tractor mod:917274660. gas not reaching fuel pump. how do I fix? installed new pump. still doesn't work
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Craftsman Master
  • 918 Answers
Unhook the fuel line at the fuel pump and see if fuel will flow from the fuel tank. if not there may be a blockage in the tank or bad fuel lines.
Posted on Apr 22, 2017
Testimonial: "very helpful. changed bad fuel lines and everything works just fine. thanks"
24 hp Craftsman lawn tractor will not start; doesn't appear to be getting gas in the carb. It is pumping through the fuel pump.
hi Vet68652, I have to agree with tomicamel, it does sound like a clogged fuel filter there is nothing else between the pump and the carb.... unless the line is clogged,
Mar 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I had a replacement engine installed. is it missing a fuel pump?
check inline fuel filter or hose to long between bottom of tank and carb
Feb 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19.5 42inch deck riding mower and no gas
just wanting to know where the gas line and air filter is on a craftsman 19.5 hp twin 42 hydro is
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
