Question about Exercise & Fitness
My truck starts but will not run new feul pump new injection spider I pour gas in throttle body and it runs perfect
What could cause this
  • 1,057 Answers
Check the fuel filter or replace it as it doesn't cost that much and check the pressure regulator to the spider. Hope this helps.
Posted on Apr 22, 2017
87 chevy 350 tbi will only start if if pour gas in the throddle body then keep it running by pumping the peddle. It seems to starve at higher rpms, and when it does idle the rpm's swing from hig
Sounds like the fuel pump is going bad(or in this case,has gone bad). I suggest that you change the fuel pump and use a fuel cleaner in your gas tank as dirty gas may have caused the problem to begin with.
Nov 27, 2012 | Chevrolet Cars & Trucks
Starting issues
So you know it is not getting fuel thru the injectors.
Have you checked fuel pressure at the rail, and do you know if the pump is running when you turn the key on ?
Sep 11, 2012 | 1998 GMC Yukon
1988 gmc sierra s-15 feul pump/feul delivery system,how it works.
start checking fuel pressure easier then changing pump re check that all is plugged in by air cleaner
Mar 10, 2010 | 1988 GMC S-15
Wont start,pour little fuel in throttle body runs 4 little, changed fuel filter,psi seems good off fuel pump
The injecters may be bad, or not getting power.Check wires to injecters @ throttle body to make sure they have not rubbed bare .
Mar 08, 2010 | 1985 Oldsmobile Ciera
99 silverado 4.3 vortec. engine turns over rapidly. plenty of spark. fuel pump runs. fuel filter not clogged. when i pour gas into the throttle body it runs until that gas runs out. what gives?
put a fuel pressure gauge on it. Check my specs because I am doing this from memory but I think it has to have at least 61 psi and anything below about 55 is not enough. I once put a brand new from the dealer on my bravada. Abter it still did not start I replace the "injector spider" to the tune of 400 buck my cost for the part only to find that the brand new feul pump was not getting enough pressure. Section 4 in a haynes manual at the parts store will give you the minimum fuel pressure.
Aug 16, 2009 | 1997 Chevrolet K1500
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
