Question about Exercise & Fitness
My 2003 chevy trailblazer starts but it fall dead as soon as it fires up it will not run
What causes this
chiquititas
  • 1010 Answers
SOURCE: 2003 CHEVY TAHOE
Yeas, its sound so, re-charge the battery.
Posted on Jun 29, 2008
SOURCE: Chevy Trailblazer 2003 ran the battery down now wont idle
try changing the air filter ,i had a problem ,at ilde in drive my trailblazer would stall, changed the air filter now it's not stalling and got my power back ,there is a secondary air pump that i have to change ,
not sure were it is ? still not running perfect but it's running better .and my service light is on too.
i got it put on scope ,it's the pump .
not sure if this helps ,but i'm start to run in to problems too,i have a 2004 trailblazer.
i like to do fix things myself ,i hope i can.it's the cost if you know what i mean.
Posted on Dec 18, 2008
  • 109 Answers
SOURCE: 2003 Chevy Trailblazer my AC blower won't turn off!
you have a short to power which will cause it to stay on constantly check your blower motor resistor pack to ensure that it is working and check the wires going to the blower to make sure you have a power and a ground
Posted on Jun 29, 2009
mech1920
  • 22 Answers
SOURCE: 2003 Chevy Trailblazer leaks a/c condensate on passenger floor.
under car pass side just behind tire on firewall looking for tube that makes 90 degree bend make sure not clogged if still leaking check for cracks in the evap case
Posted on Aug 10, 2009
SOURCE: replace low beam headlight on 2003 chevy trailblazer
I just replaced the low-beam bulb on my 2003 Chevy Trailblazer. The grill just needs to be loosed slightly. Then, raise two L shaped brackets, one on each side. For the inside one, I needed to use a flathead screwdriver to get to it. The light assembly can then be pulled out. Remove the rubber cover and rotate the bulb one quarter turn left to release it. Pull out the bulb, replace with a new one ($11.50) from Advance Auto Parts, and reverse the process. Once I figured it out, took about 10 minutes total.
Posted on Nov 06, 2009
Jump start trailblazer will run that day but next day it is dead there is a short some where
2006 Trailblazer won't start - Discussion on Topix
www.topix.com > Chevrolet TrailBlazer
Sep 6, 2012 - My 2006 Trailblazer will not start, bought a new battery, still will notstart, not even with a jump. ... i get a jump i drive it and charged the battery it seemed fine but then i went ... Then, next morning, when I turn key, all lights come on and radio... back a day and 360$ well that pos still will crank but will not start. 02 trailblazer a/c problem
Jul 21, 2011
2003 trailblazer key is stuck in ignition
Dec 21, 2009
2003 Chevy Trailblazer will not start
Jul 21, 2009
2002 trailblazers won't start
Aug 24, 2007
More results from www.topix.com
Oct 29, 2015 | 2005 Chevrolet TrailBlazer
I have a 2003 chevy trailblazer the motor did turn over and now itdont it just clicks
This usually indicates a dead battery..... But why did the battery go dead. I would try jumping the vehicle and see if it starts. If the vehicle starts carefully remove the Postive battery (red) and see if the vehicle remains running. If the vehicle stops you have a bad alternator. Or if you have a Volt meter you can check the output of your alternator should be 12-14V
Nov 28, 2014 | 2003 Chevrolet TrailBlazer
2003 chevy trailblazer service engine soon light
If the service engine soon light is flashing, it means the computer has detected an engine misfire with the potential of catalytic convertor failure. Don't just tune it up. Bring it somewhere they can read the trouble code. Sometimes it will designate which cylinder is having the problem.
Sep 24, 2014 | 2003 Chevrolet TrailBlazer
My 2003 chevy trailblazer makes a noise like pressure is releaseing as soon as turn the car off, What is this?
It is probably just your air conditioning. If you have your defrost on it also runs your ac pump. So if you have your ac or defrost on and you shut the vehicle off you will hear a hissing noise for about 10 seconds or so which is normal.
May 05, 2011 | 2003 Chevrolet TrailBlazer
2003 Chevy Trailblazer wont start
it sounds like your battery is dead charge it and try again if the starter still clicks it means it is sticking get someone to turn the key while you hit the starter body with the handle of a hammer which will free it of
Apr 01, 2010 | 2003 Chevrolet Trailblazer Ext
Jun 29, 2009 | 2004 Chevrolet TrailBlazer
Dec 17, 2008 | 2004 Chevrolet TrailBlazer
2004 chevy trailblazer 73,000 miles
the first place to start is the flashing engine lite. that means cylinders are not firing at all or improperly and driving it like that for even short period could cause heavier damage. particularly valves and cat converter(s) the computer really needs to be scanned for codes in order to proceed. did the oil lite come on before or after engine quit. after engine quit would be normal cause it stalled. its possible that it needs spark plugs and/or coils. or more
Nov 20, 2008 | 2003 Chevrolet TrailBlazer
2003 Chevy Trail blazer says service engin soon?
you have a trouble code stored. This means the pcm has detected a problem somewhere
Jul 30, 2008 | 2003 Chevrolet TrailBlazer
Exercise & Fitness Logo
26 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
