Question about Samsung Washing Machines
I have a Samsung top loader washer that is giving me an error code of 8e. What can be done with this
rickzilla
  • 706 Answers
SOURCE: Getting error code on lg front loader washer
Hello aj546,
Kinda figured there was a miscue there with your error code however... the error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)... If you still get the FE test..call for service.. That's the best I can offer via this chanel... BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open... Hope that helped you..'
Regards,
Rick
Posted on Nov 29, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 662 Answers
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
Posted on May 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: de error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My samsung top loader of 13kg shows code dE
Many Samsung top loader washers are recalled due to a severe unbalance issue that causes the top of the washer to become dislodged and fly off. Enter exploding Samsung washers in your search engine. Since your machine may be recalled, you may have a free service call coming your way anyway!
Nov 10, 2016 | Samsung Washing Machines
I have a top load samsung washer and for a while now it will give me a dc error code and won't spin all the water out of the clothes? Need help thank you
If your Samsung top loader is starting to spin, but stops after a minute or two, and starts to fill up with water again... and then after 3 times of doing this, it errors out with a DC error code, the problem could very well be with the support rods. The springs in these rods will get weak over time and allow the drum to become unbalanced during the spin cycle. Fortunately, the 4 support rods are very easy to take out and replace. And sometimes, they just need to be greased properly. I had a service technician replace my support rods, but he didn't grease the top and bottom bushings first, so my machine still wouldn't spin properly. After he left, I pull one of the support rods out, cleaned out the dried up grease where the support rods lock in, and applied a liberal amount of white lithium grease to the top and bottom bushings on the support rod. I then put it back in. I did the same for the 3 remaining support rods. Now the support rods were able to move very freely in their holders, which is necessary during the spin cycle. My machine now spins like it is supposed to and I don't get the re-fills and DC error code anymore. This webpage, http://www.appliancepartspros.com/samsung-assy-damper-owm-dc97-16350c-ap5623264.html , contains a video that shows you how to remove, inspect and grease your support rods properly. It is not hard to do, but can be a bit messy. Have gloves and/or cleaning rags handy. And if you do need new support rods, this place has them cheaper than you can get them from Samsung!!!!
Dec 14, 2015 | Samsung Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
Fault error code 8E
an 8E or 8E2 means - Sensor problem.
Feb 19, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
8E error code on samsung top load direct drive washer
Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
Dec 09, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
De error code on samsung topo loader stops working
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Washing Machines Logo
27 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
