Question about Frigidaire Refrigerators
We have a Frigidaire Gallery refrigerator. Error code 5Y EF keeps coming up. Can the refrigerator run 2 weeks without this being fixed?
3 Suggested Answers
  • 63 Answers
SOURCE: My Frigidaire Gallery refrigerator showing HI temp.and with code5Y and EF, what does it mean?
An EF code is indicative of an Evaporator Fan Circuit Failure. Can it be stopped by ice or frost? Absolutely. Press the freezer up button and the freezer down button simultaneously for 6-8 seconds and you will enter a test mode. Every time you press the fresh food button after entering the test you will advance to the next test. They are not in numerical order. Go to test 26 (The defrost circuit test) and it will show CL for closed or OP for open. If it shows OP you have a defrost issue. If CL there is no defrost problem. Next go to test 15 - keeping in mind they ( the tests are Not in numerical order). When you get to 15 press the main power on/off button. The 1st time you press it the display will show LO and the fan should be on low speed. The next time you press the power button it will show HI, and the fan should be on high. It is a twelve vdc fan motor wire colors red, yellow, brown, and blue. They originate at the j6a and j4a connectors. If the fan does not come on in the test the check will be made at the control. There should always be 12vdc between brown and red, and there should be 9 - 12 vdc between brown and yellow in the test. The blue wire is a tach wire and feeds info back to the lower control which is located behind the kick plate underneath the unit. EX factory service 22 years currently an instructor. If you are not equipped with the proper tools and or knowledge please call a competent technician. KEEP IT SIMPLE
Posted on Feb 20, 2015
  • 63 Answers
SOURCE: I have a Frigidaire gallery refrigerator with a error code 5y cf I put in new ice maker and a new control board still have same code anybody got any sugstions plase
A cf error code means there is a communication failure between the lower control and the user interface( control on the door). Communication is carried back and forth on a white wire that originates at the j9a connector on the lower control. It has three wires, one red, one black and one white wire. This wire goes from the j9a through the left door hinge and down to the user interface. If the wire integrity is intact, replace the lower control and the user interface.
How do I fix the 5Y CF code on my display on my Gallery Frigidaire and the light is out on the other side of frig, do they go hand in hand
A model# would really help diagnose your problem. It is actually sy cf which is a communication error.
The easy answer is usually to replace both boards ( the main and the ui board) but there could be an issue with a shorted wire in the door ( although I have yet to find one on a Frigidaire )
And yes, the lights go hand in hand with this error.. Fix the error and the lights come back on
Feb 10, 2018 | Frigidaire Refrigerators
My Frigidaire refrigerator that is in our cold garage has an error code of 5Y on the freezer side and EF on the frige side. What does this mean?
5Y ef means evaporator fan issue. Could be wiring to the evap fan as well.
From the site: "I had a 5y ef error and it ended up being the control board."
Here's a link to a really good video:
https://www.youtube.com/watch?v=gCRKLkk9HmA
Hope this helps:)
Jan 01, 2018 | Frigidaire Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
What do the error codes 5Y and EF mean
Hello Friend, thank you for allowing me to assist you!
If you are getting error code SY EF, it typically indicates that your refrigerator has detected a failure with the evaporator fan circuit. Let's try resetting your refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is good wait approximately ten minutes and then turn on your refrigerator. If the error code does not clear, at this point it is best to reach out to professional to check the wiring between the main control board and evaporator fan. Hope this helps! - Z
Jul 19, 2014 | Frigidaire Professional 27.8 Cu. Ft....
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What is code 5y and ef
Hi M - I am happy to assist you! Error codes SY/EF is commonly refer to a failure with the evaporator fan circuit. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, then more than likely there is a potential wiring failure between the main control board and evaporator fan. In this regard, I would personally suggest to reaching out to a repair tech to further evaluate and repair you appliance. If you have further questions, please do not hesitate to reconnect.
Jul 18, 2013 | Frigidaire FRS26H5AS Side by Side...
The temp gauge reads 5Y for freezer and EF for the refrigerator side. Appears to be not running.
did you ever find a solution? I'm having the same problem, although my fridge appears to be running
Jul 16, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
