Question about Stihl Garden
I have a stihl FS 36 and I go to pull the rope to start is and the rope won't pull.
  • 1,057 Answers
The rope pulley has either came off the pulley or the spring for the rewinder is jammed up you will need to take it a part and examine it to find the root cause. I am assuming the piston is moving and the ring is not broken or in other word there is no other problems.
Posted on Apr 22, 2017
My Stihl FS 36 will start but dies after few seconds. Have cleaned in-tank filter; replaced diaphragm but same problem exists. Could be tank breather but awkward to get at. Seems a fuel starve issue?
Hello Bob Breedon,
Big fan of STIHL... Check Fuel 50:1 mix ratio...!!
See owners manual:
Stihl FS 36 Instruction Manual Page 18
A very common mistake... is to use GASOLINE... and
forge to put in the 2-cycle oil...
As soon as the unit heats up... It will stop
(seize - in fact)...
Been there (forgot about that)
Carnac the Magnificent
Jan 16, 2018 | Stihl Garden
Sometimes when I try to pull start my Stihl Weedeater FS 36 it just free wheels and other times it will start. What could be causing this?
there is a small plastic finger in the recoil section that is broken . missing or worn out
get one from a service dealer or just about any mower shop spares
Jul 04, 2017 | Stihl Garden
Sometimes when I try to pull start my Stihl FS 36 weedeater it just free wheels and other times it will start. What could be causing this?
The mechanism is beginning to wear out. When you pull on the rope, the turning action pushes pins out from the center of the rope pulley that engage to turn the engine. These pins wear out and will eventually fail, not engaging at all. These pins may or may not be available for purchase at the small engine parts store near you, but the entire pulley assembly with new pins usually is.
Jul 04, 2017 | Cars & Trucks
My stihl weed eater fs85 hard to start when hot
Try loosening the gas cap to relieve any pressure, then tightening it back up. Usually you will just need to barely unscrew it and then screw it back even before you pull the rope.
Jul 13, 2014 | Stihl FS 85 Weed Eater
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Oct 08, 2013 | Garden
Trying to recoil a spring on start rope on a FS 55
No but you have to be very careful not to let spring go. curve on spring should match up with molded curve on the housing.
Oct 02, 2013 | Garden
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
Stihl FS 36 trimmer doesn't have power, won't rotate.
Hi, remove the wire screen from the muffler outlet, regards Phil.
Jul 01, 2012 | Stihl Garden
Replace start cord on stihl fs 36
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. `
Feb 11, 2012 | Stihl Garden
Stihl FS 55 will not start
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
Sep 06, 2009 | Garden
Garden Logo
37 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
