Question about Yamaha Music
A need a YM1040 OR SUSTITUTE PLEASE HELP
THIS IS FOR YAMAHA FC-20 THIS IC IS THE KEY ASSIGNER
Hi I need the audio output IC of Yamaha FE30 where can I get
Hi. There are two ICs, the left and right STK465 (30W+30W) power amp is one and the Centre STK085 (60W) the other.
Ebay might be of some help.
The service manual is on Elektrotanya YAMAHA FS20 FS30 Service Manual free download schematics eeprom repair...
Oct 03, 2016 | Yamaha Music
Yamaha ELectone FC-20 volume "control sliding switch" that control the volume of the upper &lower keys there are no sound only if I put some force on this "switch" Will this be very costly to repair?
Should run about $100. You can try just cleaning the slider your self first with cleaner spray sold at Radio Shack (ask the clerk which one). Be careful not to get the spray anywhere other than the slider track as it may react with other plastic parts. Spray a little then move the slide the full length a number of times,
Aug 11, 2016 | Yamaha Music
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
Sep 24, 2014 | Yamaha P95 Digital Piano
The Electone FC 20 organ's lights and bass keys are all functioning. Only the upper deck keys are not functioning at all. Only yesterday after a long wait it functions. Today, it no longer functioning...
Likely one of the cables to that manual has either oxidized contacts or come loose. This could be at either end of the cable. With it in "failed mode", try wiggling the cable(s) going to the upper manual and the problem MAY show itself.
Aug 15, 2011 | Yamaha Music
I have a electone FC 20 all indicator lights are working and the ensemble section is working drum beat is ok its just the piano keys are not working could it be a fuse blown
Not likely iit is a fuse. The keys are likely scanned as a matrix with two contacts per key. You need to get a maintenance manual for thee organ. Contact Yamaha America parts for music products. They may have the service manual on CD... they used to get $15 for the CD of the manual. Unless you can find something simple like a cable knocked off this could be hard to troubleshoot.
Feb 24, 2011 | Yamaha Music
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
How to store music we play on yamaha psr i425??? and how to transfer dat to pc? plz help
You will need the CDROM that should have come with the keyboard when you purchased it. On it will be the drivers that need to be on the computer for it to use the usb. The link to the manual is here:http://www2.yamaha.co.jp/manual/pdf/emi/english/port/psri425_en_om_a0.pdf Please look at page 86. If you don't have the CDROM you may be able to download what you need by contacting Yamaha by email through this link and asking:http://www.global.yamaha.com/support/contact.php I hope this helps.
Oct 23, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I HAVE A Yamaha PSR 260. About 8 years old. Recently it became defective.: Only the display lights up . No sound. No response to any button. When volume control is turned, I can hear the faint rustle on...
This MAY be due to a key contact or button that is STUCK "on".
Often this will freeze the controller.
Make sure power adapter is the correct one... underpowered or incorrect ones cause trouble.
Mar 20, 2010 | Yamaha Music
I Have Yamaha Electone HS-4. I already changer a fuse but i have no sound. Someone said, for change a fuse, i must change also a transistor or condensator? Help please. Thanks. andriaharifara@yahoo.fr
the problem is the main output amp. It is an IC so it is better left to a tech to put it in. Just had the same problem with mine. Seems to happen when unit is left on overnight.
Oct 19, 2009 | Yamaha Full-Size Keyboard
I have a Yamaha PSR-170 that has a jammed key
Most keyboards of that scale are not especially fragile. You may have to remove the back (lots of screws) and maybe a bezel that is across the top of the keys to get full access to the keys. The good thing is you have lots of working models --- all the other keys. So carefully consider the differences. It may be that one or more plastic parts have broken, particularly if it fell and landed with pressure on that key.
Most of the keyboard manufacturers have parts departments that can supply just the part of the keyboard you need if you can specify exactly what you want.
Sep 19, 2009 | Yamaha Portable Keyboard
Music Logo
16 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
