Question about Sanyo Televison & Video
My Sanyo tv is losing color. Can it be fixed?
    Top Expert:
  • Sanyo Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 22, 2017
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
How do you fix a purple screen on a sanyo avm2752 tv?
One color missing is the problem to your set. There is no Green color output. Check this link, and find the post discussing about one color predominant screen. You can get more details there.
Sep 23, 2012 | Sanyo AVM-2759S 27" TV
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
The right half of my sanyo tv shows green constantly how can i fix this?
check the color IC in the color circuit it is faulty.if you are not a tech kindly have a tech look at your tv for repairs.or if you dont want to go through the trouble of repair then my advise is to buy another tv.good luck.
Sep 24, 2011 | Sanyo DP19647 19 in. LCD TV
My Sanyo DS24425 tv is showing red retrace lines across the screen. The picture sometimes fades out and is replaced by these red lines. Can the tv be fixed?
yes it can be fixed. it needs replacement of a component that heats up and often due to heat it loses solid welded connection, if welded properly it returns back to normal, if not it needs replacement with substitute or comparable capacitor item removed Id codes on it
Dec 12, 2010 | Sanyo DS24425 24" TV
Green Screen on an HDTV
I do not believe there is any easy fix to this. The problem may be either in the picture tube or the related circuitry. The worst case scenario is the tube itself is failing. However, it could be as simple as a defective connection on the pc board at the tube for example. You may want to get a technician to check it out and get an estimate before you buy a new set. Good luck
Nov 25, 2009 | Sanyo HT32744 32" TV
Certain aspect of my sanyo tv are very blurred
This problem requires adjusting the Focus on the flyback . Turn the tv around and look for adjustmen slots on the back. If you can see them, use a nonmetalic small srewdriver and slighty adjust the top or left one. Be careful, it is the high voltage area
Sep 15, 2009 | Sanyo Televison & Video
Sanyo 32
resolder your tv maybe it has a cold solder
Aug 28, 2008 | Sanyo HT32744 32" TV
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Televison & Video Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
