Question about Daewoo Televison & Video
I have a Daewoo 42 inch plasma TV model no. Dpx--42a2. As TV is plugged in the stand by light just keeps blinking without any pause in between. Which of the boards could be causing this problem?
    Top Expert:
  • Daewoo Master
  • 75,599 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 22, 2017
D_LLAMA
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
  • 55 Answers
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Posted on May 09, 2009
  • 2336 Answers
SOURCE: 42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Posted on Jul 15, 2009
phil_frye
  • 295 Answers
SOURCE: The screen on my 4 yr old 42 inch LG plasma keeps
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
BoiseLCD
  • 63 Answers
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Posted on Dec 16, 2009
How to hard reset a Daewoo dpx-42a2 plasma tv
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 22, 2017 | Daewoo Televison & Video
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
PANASONIC PLASMA HD 42 INCH WONT TURN ON JUST BLINKS 10 TIMES
10 blinks of standby light with Panasonic Plasma indicates:
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
For more details visit the site named [Electro-help" The keyword to search is "Electronicshelponline"
Jul 03, 2012 | Panasonic TCP42C2 42 in TV
I have a samsung 42 inch plasama ty model spp4231 when i try trunin it on the red light comes on it blinks 5 times them truns offWhat's your problem?
Hi the blinking light is a code. The service manual for this TV will have a description of the code. do a google search for the service manual and download it.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Televison & Video Logo
77 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
