When I got my DragonTouch and set it up I did not save my password on a flash drive. I used it several times and never had a problem logging in. now it will not let me in. need to re set my password
Adromeda
  • 9 Answers
SOURCE: Hi I have a problem.
If you can, burn a cd with the Offline NT Password & Registry Editor on it.
here. Just grab the cd Image if you want to burn it to a disc
(You can use any free program like Deep-Burner, or Active-Iso to burn the image.
You can also get a floppy version, and a usb version.
The cd you will create will be bootable, so just start up your Laptop with the disc in the drive.
This utility only resets the password, if you want to recover it, you can use an Ophcrack Live Cd, available here. You can burn the iso file with Active-Iso also.
Posted on Jun 18, 2008
  • 13 Answers
SOURCE: unable to log in Windows XP
Hi
My name is Sydney, you should try to log in as administrator without entering the password that is if when installing the operating system the admin password was not set, in most cases when you switch on your computer the administrator use is not shown. So what you do is press ctrl+alt+del+del, you will have to hold ctrl+alt while you press delete twice. Then type under username administrator and on password leave it blank. if this does not work try entering your administrator password.
If this does not work, restart your computer. and go into safe mode, you can try to press F8, or F2 or Esc, depending on the make of your computer, this should be done before it shows the windows logo, at the time it is checking your drives.
in some cases you may have a problem with your keyboard, maybe some keys are sticking so you can try to use another keyboard and see if you get the same results.
if the above does not work, check to see if you computer has a recovery cd you can put this in your cd drive then restart the machine. it should ask you to press any key to boot from the cd, press any key then follow the on screen instructions. NOTE that with this process you may loose all you documents and your computer will restored to the way it was the first time you bought it.
I hope this solves your problem, but if the problem persists please do not hesitate to contact us again.
Kind regards
Sydney
Posted on Feb 10, 2009
  • 115 Answers
SOURCE: Password/Data Recovery
http://www.fileguru.com/Smart-Flash-Recovery/download
use this software and keep me posted whether it worked or not,,plz keep me posted
Posted on May 14, 2009
t_aforrester
  • 93 Answers
SOURCE: My boyfriend has a HP Pavilion ZV5000 laptop
Starting point would be to turn the computer right off including taking out the battery unplug the power supply wait a while and then reconnect power supply and restart holding down the key that allows you to enter the BIOS. Reset the BIOS to default settings and then restart. If this works then reinsert the battery and hopefully this will fix your problem.
Posted on Sep 11, 2010
Geekman
  • 32281 Answers
SOURCE: Need to reset a password
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Posted on Mar 11, 2013
How can i get my 2go password back
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgetting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live CD,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Steps:
Step 1: Download and install Windows Password Recovery Tool 3.0 in any available computer from http://www.windowspasswordsrecovery.com/windows-password-recovery-tool.html .
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck
Jun 16, 2014 | HP Computers & Internet
Tip
HOW TO REMOVE OR CHANGE ADMINISTRATOR PASSWORD WHEN LOG IN TO YOUR COMPUTER
HOW TO REMOVE OR CHANGE ADMINISTRATOR PASSWORD WHEN LOGGING-IN TO THE COMPUTER.
If you have lost or forgotten your password for logging in to a computer. Here's how to remove or bypass the password without reintalling your operating system.
Here is the procedure how to remove or change the ADMINISTRATOR PASSWORD.
1. You need to download Windows Password Unlocker in any computer and save it to CD as installer or to USB flash disk or external hard drive. Here is the link for software to download for a small fee http://www.passwordunlocker.com/windows-password-recovery.html
2. Using CD/DVD, put the CD/DVD with password remover software and boot up your computer.
3. Press any key when there is message appear to boot up to CDROM.
4. It will run the password remover and you can change or remove the password and after that it will boot it up and run without password.
5. For usb flash disk or external drive, open your log in menu and enter wrong password. After that, a reset password will appear and click the reset password. It will ask you to put new password and do not put any password and click next. Then it will open now the Windows display setting.
on Dec 24, 2010 | Computers & Internet
Tip
How to reset Windows 2008 password with less time-consuming?
If you forgot your password on Windows 2008, how will you do? Undoubtedly, most of users may turn to the administrator to reset Windows 2008 password. But what should you do if you forgot Windows 2008 administrator password? Generally speaking, it is better to find a Windows password recovery tool to solve Windows password lost problem. Here, Windows Password Unlocker Enterprise is the one which provides you an easy and safe way to reset lost Windows 2008 password. Before dealing with your password lost trobule, it is better to learn more about Windows 2008.
What is Windows 2008?
According to Wiki, Windows Server 2008 is one of Microsoft Windows' server line of Operating Systems. Officially released in February 2008, it is the successor to Windows Server 2003. Windows Server 2008 R2, a second release, was launched to manufacturing in July 2009. It expands existing technology and adds new features to enable organizations to increase the reliability and flexibility of their server infrastructures. New virtualization tools, Web resources, management enhancements, and exciting Windows 7 integration help save time, reduce costs, and provide a platform for a dynamic and efficiently managed data center.
How to reset Windows 2008 passwordï¼ÿHere, Windows Password Unlocker Enterprise allows you to use a bootable CD/DVD or USB flash drive to reset Windows 2008 admin password in 4 simple steps.(Take USB falsh drive for example)
  • Step 1: Download and install Windows Password Unlocker Enterprise.
  • Download the program in any available computer with a driver, and then start the Windows password recovery tool.
  • Step 2: Burn a bootable USB flash drive
  • domain-usb-burn.jpg1. Insert a bootable USB flash drive to computer.
    2. Select your target USB flash drive and click the Burn button to start burning.
    3. Click OK when the burning task is completed.
    domain-usb-disk.jpgAnd now the bootable USB flash drive is burned and you can use it to reset Windows 2008 password once it is lost.
  • Step 3: Set BIOS to boot from USB flash drive.
  • 1. Insert the burned USB to your locked computer.
    2. Set BIOS to boot from USB drive.
  • Step 4: Reset Windows 2008 admin password
  • After your computer restarting with the changed settings automatically in step 3, you can see the interface of Windows Password Unlocker Enterprise.
    1. Select your target Windows system if you have two Operation System.
    2. Select the way to reset Windows 2008 password, and then click Reset button.
    reset-default-domain-password01.jpgThere are 2 options for you to reset Windows 2008 admin password:
    Option 1: Reset the default administrator password to Pa123456
    Option 2: Create a new specified account to reset lost administrator password.
    3. Click Yes to confirm and continue your operation.
    4. Click OK when the administrator password is successfully reset or the specified account is created.
    reset-default-domain-password03.jpg5. Log on your computer with the new password or account.
If you choose option 1 to reset Windows 2008 admin password, you can log on your computer with the username of administrator and password of Pa123456. If you select option 2 to reset Windows 2008 password, you can log on computer again with the username of Passkiller and password of Pa123456. Please remember to delete the specified account after logging successfully.
on Nov 11, 2010 | Computers & Internet
Facebook problems
Go to your Facebook page. Click on the icon that is next to the lock in the right hand upper navigation where your name is. Click on settings edit and change your password then log out of your account. If you want your Facebook not to remember your password your need to log out every time you finish using Facebook. When you log back in it will ask you for your password.
Feb 04, 2014 | Computers & Internet
I am logout my facebook page but my password is show plz tell me
When you are using Facebook on your personal computer, saving the password so that you stay logged in makes sense.
If, however, another person begins sharing your computer, unsaving the password protects your privacy.
Both Facebook and your Internet browser can remember your password for the social networking site.
You must log out of Facebook to stop the site from remembering your password, but you can modify Internet browser settings even when you are logged in.
Click the "Account" link in the top right corner of any Facebook screen, and select "Logout" from the drop-down menu.
Uncheck the box next to "Keep Me Logged In." The next time you log in, Facebook will not save your name and password to keep you logged in indefinitely.
Clear the saved password in Internet Explorer by going to the "Internet Options" menu and clicking "Delete" in the "Browsing History" section.
Click "Delete Passwords."
Go to the "Tools" tab if you use Firefox, and select "Options."
Click on the "Security" tab and then "Saved Passwords."
Highlight the Facebook line, and click "Remove."
Dec 10, 2013 | Computers & Internet
Tip
Reset Windows XP Password with Three Common Methods
Forgot Windows XP password, don't be worried. It's very common for PC users to lose or forget Windows password as some like to set a rather complicated password. As Windows XP has been used for several years, there are various available methods that can help you to reset Windows XP password.
Method 1: Create a password reset disk to reset Windows XP password
Creating a Windows XP password reset disk is a very easy way to protect yourselves from the possibility of forgetting your password. With it, you can reset Windows XP login password easily and quickly. Don't know how to create one, just follow the instructions as below:
1.Click on Start, Control Panel and User Accounts in order.
2. Select the specified user account you want to create the Windows XP password reset disk for.
3. In the Related Tasks area on the left, click the Prevent a forgotten password.
4. When the Forgotten Password Wizard window appears, click Next.
5. Follow the Forgotten Password Wizard to create your Windows XP password reset disk.
Once you find your Windows XP password is lost or forgotten, just reset Windows XP password with the disk. The Windows XP password reset disk can be repeatedly used to reset password for your computer, so please remember to keep it in a safe place. Otherwise, unauthorized users can log on your computer and get access to the precious data on it. It will be a disaster for you if your privacy is leaked out.
Method 2: Log on as administrator to reset Windows XP password
All Windows XP computers have a special user account named "Administrator" and by default this account is not password protected. If you don't set password for the account or you remember its password, you can log on computer with the administrator account to perform Windows XP password reset.
1. Start the computer.
2. Press Ctrl+Alt+Delete twice when you see Windows XP login screen.
3. When Log On to Windows dialog box appears, type Administrator in the User name box.
4. Type the administrator password in the password box, and then click OK. Or you can directly click Ok if you don't set password.
5. Click Start > Run > Type control userpasswords2 > click OK.
6. On the Users tab, click the name of the user account that you want to reset the password for, and then click Reset Password.
7. Set your new password and click OK on the Reset Password dialog box. And then click OK on user tab.
8. Restart the computer, and then try to log on to Windows again.
Method 3: Burn a USB flash drive to reset Windows XP password
In addition to the two methods above, you can also perform Windows XP password reset with third party Windows password recovery software. It can help you reset Windows XP login password by burning a bootable CD/DVD or USB flash drive. Before starting to perform Windows XP password reset with this method, you need to find a computer with optical driver that you can log on. Then, you can follow the below steps to burn a USB flash drive with Windows Login Recovery.
1. Download Windows Login Recovery and install it.
2. Burn the ISO image file on the program to a USB flash drive.
3. Set your locked computer to boot from USB drive.
4. Reset forgotten Windows XP password with the burned USB flash drive.
The above 3 methods are easy for you to reset Windows XP password. Of course, method to perform Windows XP password reset is not limited to the 3 options. There are still other options for you, like using a Windows installation disc to recover Windows XP password. You just find one suits you best to reset your lost Windows XP password.
on Sep 05, 2010 | Computers & Internet
How do i prevent a forgotten password on the administrative without a reset disk
Hi that_1red_bo,
I think you can create a reset disc using a USB flash drive incase you forget your password you can use that USB to reset your password for your machine with out having to reinstall windows all over again on the issue.
  • Turn your computer ON and log into Windows 7
  • Insert a USB flash drive into your computer any size would do fine, this will only take a small portion for the reset disc and can still be used for saving other files on the USB.
  • Click Start, Control Panel, User Accounts and Family Safety, User Accounts, Create a password reset disk.
this should create a USB reset Disc for you windows, and still let you use your Flash drive to save files that you will carry anywhere that you need access to.
I hope this will be Helpful to your quetion.
thanks.
Apr 07, 2011 | Sony VAIO VGC-RB40 PC Desktop
Need to change password
Log on to youre router.(@IE 192.168.1.1 IF YOU NEVER SET THIS UP BEFORE THE PASSWORD IS ADMIN IN LOWERCASE,LEAVE USERNAME BLANK)Go to the wireless setup under wireless security choose WEP there input a pass phrase and click on generate,make a note of it,THE FIRST NUMBER GENERATED AT THE TOP IS YOUR WEP KEY EVERY COMPUTER IN YOUR HOME USING THE WIRELESS INTERNET WILL NEED THIS KEY,, SAVE THE CHANGES.Now you will need to change the administrator password as well.Under administration input your new password (TWICE TO CONFIRM),Save and exit.
Good Luck
Oct 11, 2009 | Electronics - Others
How can I recover my windows password?
You should probably move the hard drive to another computer to be safe and download the saved files you need. That may be hard to do as sometimes windows will lock you out of the Documents and Settings Directory. You can use Vista though to take ownership of those directories and get your saved information.
I do notice that a lot of people that password their computers are a little sloppy when installing windows though. They kind of skip over the initial user login and password for Admin. Try logging is as Admin and use nothing for the password and see if you can log into the computer. A lot of people just hit enter when they see this screen which makes Admin and user with a blank password.
Sep 25, 2009 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
