I have a scepter x50 model led tv. I am getting a "no input" message from all 3 hdmi ports. Any idea on common issues for these televisions? I am very good at troubleshooting.
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
  • 3741 Answers
SOURCE: I have a 37" Insignia
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 16, 2009
SOURCE: Bose GS 321 HDMI issue.
Hi, did you manage to fix it? I have the same problem. Would appreciate if you can share some results if you have any.
Many thanks, Jeffrey jeff@worldmail.nl
Posted on Apr 04, 2010
tgr2000667
  • 30 Answers
SOURCE: I cannot get the Input
input is shared with component input--one or the other --must choose in set up menu
Posted on Jul 13, 2010
How do I get the high def side my Dynex 40in LCD tv to work
TRY connecting thru your composite connections to see if that works, also try a new HDMI cable. if it works thru composite & not the HDMI input then you have either a source issue or a bad MAIN/IO PCB
Sep 23, 2014 | Dynex DX-L42-10A 42 in. LCD TV
Akai LCT3785TA HDMI Not Working with my AppleTV 3
Have you made sure you are plugging the HDMI into the right HDMI port? Many TVs have multiple ports and you can usually use the remote to switch to the proper one. Once you find the "input" menu on the TV you an run through all of then until you find a signal, or look at the HDMI port number on the back of the TV and then select that port. I do not think it is an issue of getting a better calbe.
Other possibility is that the Mac is not sending a signal - and for that you need a Mac person.
Jan 13, 2014 | Akai LCT3785TA 37 in. LCD HDTV
Inputs not working
Sounds like the main board has gone bad. But! what is the model number and brand?
Dec 19, 2013 | Sony KDL55EX620 55 LED HDTV
Hisense 46" LED HDMI sound problems when connected to directv H44/700 genie
This issue is usually caused by a bad cable or a excessively long cable.
To test this try this cable on anther port or TV, also turn the cord around and try the opposite ends in the TV.
If you find that the cord works on another TV than chances are it's the port on the TV or other appliance.
You should have more than one HDMI input you can also try using one of those and seeing of that resolves the issue.
Oct 20, 2013 | Generic F46K20E Hisense 46 in. LCD HDTV
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Which HDMI input do I use for my cable TV box to the TV 1 or 3
The input port number is not important, but #1 would be the most common port selected.
Jul 17, 2011 | Pioneer PureVision PDP-4340HD 43 in....
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
