Question about The Music
The 6122 Country gentleman guitar, had some pickguards with Chet Atkins signature how can I find out how many signed guards there where
    Top Expert:
  • The Master
  • 3,113 Answers
Your best bet would be to contact Gretsch Consumer Service, which is the same numbers as Fender.
Posted on Apr 23, 2017
Peavey rockmaster pickguard
Nov 14, 2013 | Fender ® Frontman 15R Electric Guitar...
Looking for year model for an epiphone sst studio serial # 10082302339
check out giovanni stores do will be able to help you, it belongs to the chet atkins family guitars
Dec 01, 2011 | Epiphone SST Studio Guitar Acoustic
I was just playing my guitar, and everything was fine. Then, I sat it down for 5 minutes, and when I came back, all the sudden the "Tone" knob was loose and wiggly. Is there any way to fix this...
take the screws out of the pickguard assembly and raise it up enough to get your hand in there, pull the knob off the tone control, now hold the back of the pot (tone contorl) with one hand while you retighten the nut that holds the tone control to the pick guard, tighten the nut with a pair of pliers being careful not to scratch the pick guard, put the pickguard back in place and put the screws back in. You might want to check all the other controls to make sure they are tight or the same thing will happen to them The Peavey Rockmaster set up is a nice guitar and amp
Mar 20, 2011 | Peavey Rockmaster Guitar Stage Pack -...
I get static pops when playing my new Gretsch G5120. How can this be resolved?
First verify that OTHER guitars work flawlessly with the same cable and amp.
This is the season of low humidity and static discharges. These are usually reduced by raising humidity to 40% or greater.
Static develops from certain clothing and shoes rubbing and can discharge through the guitar cable as it builds up. If you can shuffle your feet and cause more static, then get some "Staticide" spray to spray on the floor where you perform.
I would NOT modify your guitar due to the value of it unless you find a broken ground wire someplace.
Mar 12, 2011 | Gretsch G6120 1959 Chet Atkins Hollow Body...
1st string pings
This is likely a setup problem and since this is a high value guitar, you are best to take it to a competent shop for adjustment... It should cost very little to make it right. If the strings are old, you MIGHT want to try a new set first.
Oct 27, 2010 | Gretsch G6120 1959 Chet Atkins Hollow Body...
I'm looking for a black pickguard for washburn g2-v any help would be awesome!!
For standard unbranded guitar parts, I generally search on <generic online auction site>.
make sure you get a pickguard with the right cut-outs for your pickup arrangement (humbucker / single coil).
Apr 21, 2010 | Music
When i shake the guitar i hear static sound thru amp. sounds like a bad ground. how do you remove switch, jack and pots to check connections?
LIKELY this is a TYPICAL poor connection at the jack. It is not uncommon to have slight noise IF the plug moves as you shake it.
AS A test, restrain the plug so it can't move.
Another source is a FAILING instrument cable. Get ones with GOLD plated ends as they are less prone to oxidation.
ONLY open the guitar after you have exonerated the cable. The jacks do wear, but more commponly the cable is at fault. The connections inside are USUALLY solid and NOT a problem.
If you can access the jack, you could increase the spring tension.
First though, see if moving the plug where it plugs in creates noise.
Oct 09, 2009 | Gretsch G6120 1959 Chet Atkins Hollow Body...
Music Logo
18 people viewed this question
Top The Music Experts
Kyle Steven OHare
Kyle Steven OHare
Are you a The Music Expert? Answer questions, earn points and help others
