Question about Bosch Washing Machines
Bosch front loader won't lock door to allow programme to stArt
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 197 Answers
SOURCE: Indesit WIA 121 washing machine,
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Posted on May 17, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
SOURCE: How do I replace the door seal to a Bosch Front
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Posted on Feb 18, 2010
  • 343 Answers
SOURCE: my washing a whirlpool awo 10761 front loader,when
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Posted on Apr 18, 2010
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts -
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
F61 code door won't open
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
Dec 05, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Kenmore front loader washing machine won't start
You will need to replace the door lock. Here is the part to order.
To replace the lock, remove the band securing the boot to the front panel and fold back the door boot. Now you can access and replace the lock. Let me know if you should need further help.
Nov 05, 2012 | Washing Machines
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Oct 05, 2008 | Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
