Question about Simpson Washing Machines
My simpson eziset750 has a hot and cold feed at the back of the machine. Is the water heated with an element or does it have to be connected with an actual hot water supply?
    Top Expert:
  • Simpson Master
  • 48,191 Answers
In australia there are no heating elements in the simpson washing machines
connect the red fitting to the hot water tap
Posted on Apr 22, 2017
I have no hot water as heating element waiting for repairs.Ia it ok to use washing machine with just cold water
Yes its fine. Most washers only have a cold feed anyway. But if yours as hot and cold the washer will heat it up
Mar 25, 2017 | Washing Machines
Simpson eziset750 washing machine that washes but don't spin
Lid switch / drip dry botton on / wash/spin solenoid fried /
Aug 12, 2013 | Washing Machines
Does the WM65 have a heating element and would you recommend using direct hot and cold or just cold?
Washing machines do not have an internal heating element . My cousin uses cold only on all of her washing .
Jan 22, 2018 | Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
you can pick up a Y adaptor from a hardware store and fit a cold feed to both, it will take a few more minutes to comlpete cycles thats all, all new machines are fitted with a cold feed only to make them more energy efficent. the tech is talking pi**
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover HW160m - double inlet but only 1 tap at new build.
You can use the cold water only with no issues at all. The only thing you will have to do is buy a cap to block off the hot water inlet on the back of the machine otherwise the cold water will flow out through it onto your floor etc.
And yes, your machine has an element built in which will heat the water for you!
Jun 18, 2009 | Hoover HW160M Front Load Washer / Dryer
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Washing Machines Logo
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
